Save Screenshot (glReadPixels) fails under Wayland #98462
Reference: blender/blender#98462
When running Blender under Wayland, taking a screenshot doesn't work,
it just produces a black image.
Steps to reproduce:
NOTE: Calling
bpy.ops.screen.screenshot(filepath="/tmp/screen.png")
is also a quick way to test this.system-info.txt
I looked into a fix but couldn't find a solution, opening this report.
Findings so far:
da9e14b0b91c81d29c4e44f40ac299ae847367de
.glReadPixels
works as expected for off-screen buffers, it only fails when reading from the front-buffer.Screenshot fails under the following configurations:
These Configurations Fail
WITH_GHOST_WAYLAND
enabled andWITH_GHOST_X11
disabled.WITH_GHOST_WAYLAND
enabled.LIBGL_ALWAYS_SOFTWARE=1 GALLIUM_DRIVER=llvmpipe
,WITH_GHOST_SDL
in Wayland.These Configurations Work
Xwayland
withWITH_GHOST_X11
enabled.Xwayland
withWITH_GHOST_SDL
enabled.Other details
Return GL_UNSIGNED_BYTE & GL_RGBA, which is whats being used.
Since screenshot works in SDL+X11 but fails in SDL+Wayland,
it seems there may be some limitation in the Wayland OpenGL implementation.
... from looking further online there seems to be issues with Wayland & glReadPixels but most of the information I found related to embedded devices.
Added subscriber: @ideasman42
I have no idea about this area, but this also crashes Blender with a use-after-free ASAN report for me, so I can "confirm" this.
Added subscriber: @christian.rauch
Does this also appear with EGL on X11 (
WITH_GL_EGL=ON
butWITH_GHOST_WAYLAND=OFF
)?Which driver are you using? Your log says "
AMD Radeon RX 5700 XT (navi10, LLVM 13.0.1, DRM 3.44, 5.17.9-arch1-1)
" which sounds like software rendering through LLVMpipe.@christian.rauch yes,
WITH_GL_EGL
in X11 works.The driver being used is AMDgpu: https://en.wikipedia.org/wiki/AMDgpu_(Linux_kernel_module) I don't think I can use alternative drivers, besides software rendering (the closed source AMD drivers only seem to work for Xorg).
Some things worth checking:
If this is intentional & can't be worked around on our side. we could avoid using
glReadPixels
which is only used screen-shot and as a fallback forUI_OT_eyedropper_color
(when accessing image pixels directly isn't possible).Possible ways to avoid could be to access the textures used to draw the area/region (in the case of sampling).
In the case of screen-shot it may also be possible to access the textures used for drawing the window. Or, use the wayland API to access this info (check on how wayland screen-shot tools such as grim work https://git.sr.ht/~emersion/grim ), then access screenshot as part of ghost.
As I don't think this is all that high priority, we could even disable screenshot for wayland until a solution is found. (or disable for AMD if this only impacts AMD).
@HooglyBoogly what hardware are you using and what was the ASAN crash?
Hmm, I actually can't reproduce this anymore. I think I was using the built-in gnome screenshot tool, but that does sound a bit weird.
Now Blender's screenshot operator seems to work fine too.
Just in case:
@HooglyBoogly does it work with
WITH_GHOST_X11=OFF
andWITH_GHOST_WAYLAND=ON
? (As X11 under Xwayland works for me too).Yeah, everything seems to work fine for me with those build options. I'm using Fedora 36 with Wayland. I wish I took more detailed notes of the problem before. Just in case, I checked
WITH_GL_EGL
and it also worked.This issue was referenced by
48da8c4040
This bug was caused by the behavior of
eglSwapBuffer
, On my systemEGL_BUFFER_PRESERVED
is not supported, so accessing the front-buffer isn't a reliable way of reading the image. Although it does work under some conditions, for example - removing the redraw before reading the front-buffer works as expected. There is an issue with drawing into the back-buffer, callingeglSwapBuffer
then immediately accessing the front-buffer. Given some time for wayland to draw the window this should work, but when these commands run without time for the egl-surface to draw it fails.It's possible to redraw then read from the back-buffer, or tweak buffer swapping to make it work but this seems too fragile and likely to break (since drawing doesn't always call buffer-swap).
So I've committed off-screen buffer drawing instead, while this is a workaround I don't see any down-sides as this is more likely to give correct output in some corner cases (minimized window, partially off-screen windows ... etc).
