Measureit arc angle doesn't work #98557
Blender Cloud
Documentation
Eevee & Viewport
Import and Export
Rendering & Cycles
Add-ons (BF-Blender)
Add-ons (Community)
2 Participants
Reference: blender/blender-addons#98557
Operating system: Windows-10-10.0.19044-SP0 64 Bits
Graphics card: AMD Radeon RX 6600 ATI Technologies Inc. 4.5.14800 Core Profile Context 22.5.1 30.0.15021.11005
Broken: version: 3.3.0 Alpha, branch: master, commit date: 2022-05-20 22:53, hash:
blender/blender@dfb8c90324
Addon Information
Name: MeasureIt (1, 8, 1)
Author: Antonio Vazquez (antonioya)
[measureit addon with arc and angle does not work]
[open the blender, use default cube, go to edit ,open measureit from side menu, select 3 vertices ,click arc or angle does not show values.]
Added subscriber: @a_kira_in_agawa
MEASUREIT ARC ANGLE DOES NOT WORKto Measureit arc angle doesn't workAdded subscriber: @OmarEmaraDev
Just to double check, did you make sure to press Show in the add-on panel to actually show the arc or angle that was added?
