Regression: Crash when adding color attribute in edit mode #98673
Closed
opened 2022-06-08 17:00:37 +02:00 by Dvorakir · 16 comments
Graphics card: NVIDIA GeForce GTX 1070 Ti/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 511.65
Broken: version: 3.2.0, branch: master, commit date: 2022-06-08 10:22, hash: e05e1e3691
Worked: 3.1
Caused by 3d5f5c2d9a
Adding a color attribute to a mesh from the Color Attribute panel causes a crash if the object is in edit mode.
A crash does not occur if a color type attribute is added manually from the Attributes panel
Based on the default startup file:
  1. enter edit mode on the cube
  2. try adding a color attribute
  3. crash
blender_2022-06-08_16-58-25.mp4
**System Information** Operating system: Windows-10-10.0.19043-SP0 64 Bits Graphics card: NVIDIA GeForce GTX 1070 Ti/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 511.65 **Blender Version** Broken: version: 3.2.0, branch: master, commit date: 2022-06-08 10:22, hash: `e05e1e3691` Worked: 3.1 Caused by 3d5f5c2d9a **Short description of error** Adding a color attribute to a mesh from the Color Attribute panel causes a crash if the object is in edit mode. A crash does not occur if a color type attribute is added manually from the Attributes panel **Exact steps for others to reproduce the error** Based on the default startup file: 1. enter edit mode on the cube 2. try adding a color attribute 3. crash [blender_2022-06-08_16-58-25.mp4](https://archive.blender.org/developer/F13138594/blender_2022-06-08_16-58-25.mp4)
Author
Added subscriber: @Dvorakir
#99160 was marked as duplicate of this issue
#98819 was marked as duplicate of this issue
Added subscriber: @iss
Can confirm, in debug build this triggers assert BLI_assert(me->edit_mesh == nullptr);
 	blender.exe!_BLI_assert_abort() Řádek 47	C
>	blender.exe!ED_mesh_color_ensure(Mesh * me, const char * name) Řádek 430	C++
 	blender.exe!vertex_color_set<blender::ColorSceneLinear4f<0>,blender::color::FloatTraits,0>(Object * ob, blender::ColorSceneLinear4f<0> paintcol_in, blender::ColorSceneLinear4f<0> * color_layer) Řádek 4104	C++
 	blender.exe!paint_object_attributes_active_color_fill_ex(Object * ob, blender::ColorSceneLinear4f<0> fill_color, bool only_selected) Řádek 4172	C++
 	blender.exe!BKE_object_attributes_active_color_fill(Object * ob, const float * fill_color, bool only_selected) Řádek 4200	C++
 	blender.exe!blender::ed::geometry::geometry_color_attribute_add_exec(bContext * C, wmOperator * op) Řádek 241	C++
 	blender.exe!wm_operator_exec(bContext * C, wmOperator * op, const bool repeat, const bool store) Řádek 1099	C++
 	blender.exe!WM_operator_call_ex(bContext * C, wmOperator * op, bool store) Řádek 1147	C++
 	blender.exe!dialog_exec_cb(bContext * C, void * arg1, void * arg2) Řádek 1427	C
 	blender.exe!ui_apply_but_funcs_after(bContext * C) Řádek 1038	C
 	blender.exe!ui_popup_handler(bContext * C, const wmEvent * event, void * userdata) Řádek 11522	C
 	blender.exe!wm_handler_ui_call(bContext * C, wmEventHandler_UI * handler, const wmEvent * event, int always_pass) Řádek 732	C++
 	blender.exe!wm_handlers_do_intern(bContext * C, wmWindow * win, wmEvent * event, ListBase * handlers) Řádek 3166	C++
 	blender.exe!wm_handlers_do(bContext * C, wmEvent * event, ListBase * handlers) Řádek 3285	C++
 	blender.exe!wm_event_do_handlers(bContext * C) Řádek 3878	C++
 	blender.exe!WM_main(bContext * C) Řádek 626	C
 	blender.exe!main(int argc, const unsigned char * * UNUSED_argv_c) Řádek 551	C
 	[Externí kód]
Can confirm, in debug build this triggers assert `BLI_assert(me->edit_mesh == nullptr);` ``` blender.exe!_BLI_assert_abort() Řádek 47 C > blender.exe!ED_mesh_color_ensure(Mesh * me, const char * name) Řádek 430 C++ blender.exe!vertex_color_set<blender::ColorSceneLinear4f<0>,blender::color::FloatTraits,0>(Object * ob, blender::ColorSceneLinear4f<0> paintcol_in, blender::ColorSceneLinear4f<0> * color_layer) Řádek 4104 C++ blender.exe!paint_object_attributes_active_color_fill_ex(Object * ob, blender::ColorSceneLinear4f<0> fill_color, bool only_selected) Řádek 4172 C++ blender.exe!BKE_object_attributes_active_color_fill(Object * ob, const float * fill_color, bool only_selected) Řádek 4200 C++ blender.exe!blender::ed::geometry::geometry_color_attribute_add_exec(bContext * C, wmOperator * op) Řádek 241 C++ blender.exe!wm_operator_exec(bContext * C, wmOperator * op, const bool repeat, const bool store) Řádek 1099 C++ blender.exe!WM_operator_call_ex(bContext * C, wmOperator * op, bool store) Řádek 1147 C++ blender.exe!dialog_exec_cb(bContext * C, void * arg1, void * arg2) Řádek 1427 C blender.exe!ui_apply_but_funcs_after(bContext * C) Řádek 1038 C blender.exe!ui_popup_handler(bContext * C, const wmEvent * event, void * userdata) Řádek 11522 C blender.exe!wm_handler_ui_call(bContext * C, wmEventHandler_UI * handler, const wmEvent * event, int always_pass) Řádek 732 C++ blender.exe!wm_handlers_do_intern(bContext * C, wmWindow * win, wmEvent * event, ListBase * handlers) Řádek 3166 C++ blender.exe!wm_handlers_do(bContext * C, wmEvent * event, ListBase * handlers) Řádek 3285 C++ blender.exe!wm_event_do_handlers(bContext * C) Řádek 3878 C++ blender.exe!WM_main(bContext * C) Řádek 626 C blender.exe!main(int argc, const unsigned char * * UNUSED_argv_c) Řádek 551 C [Externí kód] ```
Member
Added subscriber: @lichtwerk
Philipp Oeser self-assigned this 2022-06-09 09:12:27 +02:00
Member
Will check
Will check
Philipp Oeser changed title from Crash when adding color attribute in edit mode to Regression: Crash when adding color attribute in edit mode 2022-06-09 10:11:24 +02:00
Added subscriber: @beta-tester
Philipp Oeser removed their assignment 2022-06-23 18:31:12 +02:00
Member
I claimed this because I thought I had the fix already, turns out there might be a better way to do it.
Cannot tell if I can get a solution for 3.2.1, so will step down if others are quicker...
I claimed this because I thought I had the fix already, turns out there might be a better way to do it. Cannot tell if I can get a solution for 3.2.1, so will step down if others are quicker...
Member
Added subscriber: @Shady.Hamza
This issue was referenced by 30273b86c7
This issue was referenced by 30273b86c7ffc79746d21952970fec25db523c1c
Member
Joseph Eagar self-assigned this 2022-06-27 02:11:53 +02:00
Member
Member
Mentioned the task and commit in corrective release list. Feel free to remove if fix is not appropriate for backporting
This issue was referenced by 4b7eaa709f
This issue was referenced by 4b7eaa709f73b43ca6b141be59f9c9b1e0950d8f
8 Participants
Reference: blender/blender#98673
