FBX exporter ignore new vertex colors attribute #98721
Blender Cloud
Documentation
Eevee & Viewport
Import and Export
Rendering & Cycles
Add-ons (BF-Blender)
Add-ons (Community)
8 Participants
Reference: blender/blender-addons#98721
Graphics card: NVIDIA GeForce RTX 2060 SUPER/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 512.15
Broken: version: 3.2.0, branch: master, commit date: 2022-06-08 10:22, hash:
blender/blender@e05e1e3691
Create any mesh
Enter in vertex Paint
add a new vertex color attribute (color or byte color)
paint some vertex colors in the mesh
Export to FBX
import in any software or see in the windows 3D viewer.
In my tests (unreal, max and windows viewer) no program found any vertex color data.
Added subscriber: @AlbertoVelazquez
I'm checking that same problems happens with all importers that I have tried (OBJ/GLTF) so I suppose that all exporter are affected.
Added subscriber: @OmarEmaraDev
I can't seem to replicate that. Importing back into Blender yields the same vertex colors. You perhaps attach a simple file that reproduces the issue, along with its exported FBX.
I created a blend test file
With this results
Blender Color Attribute Test file.blend
Vertex Color.fbx
Vertex Byte Color.fbx
Face Corner Color.fbx
Face Corner Byte Color.fbx
Like I see is a limitation of what type of attributes is used in the exporter.
I see, you are right. Currently, Blender have a limited definition of what vertex colors are, and those are the face corner byte colors. Exporters just use the vertex colors that Blender provides through its API.
So the issue reported here is a request for modified/improved behavior and not a bug in current behavior. Closing as this bug tracker is only for bugs and errors.
For user requests and feedback, please use other channels: https://wiki.blender.org/wiki/Communication/Contact#User_Feedback_and_Requests
For more information on why this isn't considered a bug, visit: https://wiki.blender.org/wiki/Reference/Not_a_bug
@OmarEmaraDev I have same opinion that you, but it will create a lot of insecurity in users. Cannot be the user warned in some way? It will be hard for user to know this limitation without trial and error.
How do you suggest the exporters can warn the user?
In principle, I can think of two ways.
The first one seems to me the most correct. A warning where it says "Only Face Corner Byte Color will be considered by the exports".
And, besides, it should be documented in the manual.
I think this should go the manual and tool tips in the exporter for now at least.
Added subscriber: @aras_p
OBJ should actually work just fine, in Blender 3.3 - can you try an alpha build from https://builder.blender.org/download/daily/ ?
I don't usually export in OBJ, so I don't know if the default options are asl correct for exporting vertex color. But I have not been able to get max or windows viewer to find a vertex color channel in any of its forms (vertex, facecorner) or types (color or byte).
Added subscriber: @BlenderInsight
I think this should be considered a bug for now and not a future feature.
The reason for it is that this change where you suddenly have to go from Vertex Colors to *"Face Corner + Byte Color" makes it impossible to Geometry Nodes to set Vertex Colors to "Byte Color" as output since it does not support "Byte Color" as output...only "Color" in .3.2.
So this change broke a all my stuff that I had built in Geometry nodes where I use Vertex Colors and want to Export as FBX in to Unreal Engine.
It worked fine before this possibility to tell Blender what type of Vertex Color it should use.
Added subscriber: @dpotuznik
Hi,
for me too is more of a bug.
because on all 3D software when we deal with vertex color is ... a vertex color that it..
for me you add more confusion to the user, I am pretty new on blender (Thank you for this amazing software :) ) ..
for example, I still don't know how I can export the vertex color to Unreal.
i have made a bake material color to vertex color save the object on fbx , and when I try to reload the fbx on blender the vertex color is gone !
so how can I export vertex color on fbx ?
Thank you for your hard work
have a once day
Daniel
or maybe , can you on the export option add an option like "convert Face to vertex color"
or even simply auto convert vertex color to Face Corner when you export on gltf or fbx ... to be seamless for the user ?
Added subscriber: @panakotta00
First comment here,
I just wanted to let you know I got the vertex colors working with unreal.
In the Unreal Import Settings, change "
Vertex Color Import Option
" to "Replace
".I then was able to import vertex colors of type "Face Corner - Byte Color".
Changed status from 'Archived' to: 'Confirmed'
This issue was referenced by
692f4691ab
Fixed by D15942
Added subscriber: @IgorFrolov
