Regression: Eevee shader compilation error #98825
8 Participants
Reference: blender/blender#98825
Graphics card: NVIDIA GeForce RTX 2060/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 511.79
Broken: version: 3.2.0, branch: master, commit date: 2022-06-08 10:22, hash:
e05e1e3691
Worked: version: 3.1.2, branch: master, commit date: 2022-03-31 17:40, hash:
cc66d1020c
Caused by
281bcc1c1d
Shader compilation of material in provided file was working correctly in 3.1.2, but fails to create material in 3.2 resulting in pink material while viewing in eevee
eevee 3.2 shader error.zip
Some notes:
Open provided file. Texture on mesh is pink when showing in eevee, but renders correctly in cycles.
Removing various nodes from affected material like color, mix rgb, or color ramp doesn't seem to solve it. But once texture is removed, issue is gone. I have 9 UDIM textures there with 6 tiles each. Which results in 54 texture files. It seems that removing one UDIM texture from node tree lowering used files count to 48 is fixing the issue. Was there some limit introduced?
Worked on it a bit more in 3.1.2 and currently at 11 UDIM textures with 6 tiles each it still works. In 3.2 at this point I have to remove 3 textures to get below 9 as described above. SO if this is some limitation I'm hitting, it seems to be significant difference when going from 3.1.2 to 3.2
Added subscriber: @VGT
#100817 was marked as duplicate of this issue
Updated GPU drivers to NVIDIA 512.95 - same result.
Added subscribers: @kevindietrich, @deadpin
@kevindietrich Seems like
281bcc1c1d
caused the issue here.Notes from a quick investigation:
It seems like there is some memory corruption, where
GPUCodegenCreateInfo.sampler_names
does not reallocate properly the name arrays when there is more than 16 samplers, which creates the very first error in the log (unexpected reserved word "layout"...
because the previous line is not finishedlayout(binding = 16) uniform sampler2DArray\n
). Increasing the default allocation size ofGPUCodegenCreateInfo.sampler_names
to 32 fixes this issue. However, there is still a shader compilation failure as we have more than 32 samplers (Error: C7612: profile doesn't support more than 32 samplers
).Added subscriber: @PratikPB2123
Eevee shader compilation errorto Regression: Eevee shader compilation errorAdded subscriber: @fclem
@kevindietrich My bad! For some reason I though
std::array
would be a container with a fixed storage. So for it to work we need to store the char array as one object. Using aunique_ptr
should do the trick.Added subscriber: @ThomasDinges
Blender 3.2.1 is scheduled for release soon. Any chance to fix this still? @fclem
This issue was referenced by
5b1a8a0e2f
45fb7a1db5
@fclem When opening provided file example in 3.2.1 shader is still pink, but error in window console is different - 32 samplers limit mentioned by @kevindietrich
Does this mean that because of internal changes to Eevee implemented for 3.2.0 it will not be possible to make it work as in 3.1?
Should I report 32 samplers limit as a separate bug in that case?
@VGT this limit is is just a limitation of the hardware/driver. It is not a bug.
@fclem in that case what has changed that it was working in 3.1.2?
@VGT that is a good question I'll investigate.
It may be caused by the manual indexing of samplers. In the past, the driver might have reused unused internal sampler slots so that more user textures can be used. Now that we rely on manual sampler location (for future vulkan compatibility), doing the same thing means doing it ourselves instead of letting the driver handle this.
Changed status from 'Resolved' to: 'Needs Developer To Reproduce'
@fclem Thank you for explaining this and committing to further investigation.
Added subscriber: @Thura
Fixed by #105772.
