Unexplained reflection logic (artifacts) on water shader with bump mapping #98869
2 Participants
Reference: blender/blender#98869
Operating system: Windows-10-10.0.19044-SP0 64 Bits
Graphics card: NVIDIA GeForce RTX 3080 Ti/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 512.59
Broken: version: 3.2.0, branch: master, commit date: 2022-06-08 10:22, hash:
e05e1e3691
Worked: Probably never
Unexplained reflection logic (artifacts) on water shader with bump mapping.
The object “Water_Large_SimpleReflection” shows the result without any bump mapping. The reflection is accurate. The object “Water_Large” shows the result with bump mapping applied. Naturally, the reflection is distorted because of the angle of the waves created on the reflection. That is normal, but the reflection of a portion of the rectangles is offset with wrong placement.
The problem:
For a reason that I really cannot explain, the rectangles of 45 degrees are reflected vertically on the water surface from a precise horizontal position. Without expecting perfection, the reflection should have been displayed with an average of 45 degrees on the water. It is like a threshold where the reflection logic changes See the screenshot and check where the red arrow is for an indication.
Observations:
As you can see on the screenshots, a part of the far objects is being reflected correctly on the water surface, but the majority of the color is not aligned with the angle of the object. Strangely, the objects are being reflected at 45 degrees from the far horizon line and suddenly, from a virtual horizontal line, they start reflecting vertically as if the objects were totally vertical. And that happens at a precise vertical height on the water surface. This is exactly where the problem happens.
For years, I have never seen any issues with reflections. If you have a scene with a city skyline in the horizon, you are less likely to see that kind of artifacts. In the present case, we have the equivalent of skyscrapers, but at 45 degrees.
I also tried with Blender version 2.93 and the problem is the same.
Before reporting this bug, I looked at the scene setup. To validate the nature of the problem, I decided to take into account the following factors.
I was not sure if that was a bug in Cycles or a limitation. I relied on the definition that has been given to me, “if it works as expected”, and clearly it is not working as expected. Therefore, I decided to report it.
ReflectionBug.blend
Added subscriber: @SebBlender
Added subscriber: @mano-wii
Changed status from 'Needs Triage' to: 'Needs Developer To Reproduce'
If fact is not the result that would be expected.
But as it is something as common as the bump, I avoid confirming it as a bug for now.
Needs Information from Developers
