Math "fraction" and "modulo of one" node outputs 1.000 #98877
Reference: blender/blender#98877
Operating system: Windows 11
Graphics card: NVIDIA GeForce RTX 3080 Laptop GPU
Broken: 3.2.0
Math "fraction" node and "modulo of one" can output one, it probability has to do with precision.
It's happening when trying to perform on fractions bigger than 0.9995.
The same problem for both shader nodes and geometry nodes.
Example and way to reproduce:
Work around
Work around for the mean time, you can use "less than" and multiply the resalt by the fraction resalt. i've found threshold value of 0.9995 to work.
this if basically the same as doing:
if fraction is greater than 0.9995 return 0 else return the fraction
Added subscriber: @AviCohen
Added subscriber: @mod_moder
This is not a bug, but a problem of format accuracy limitations?
if you mean it's the format of the output than no, it actually affects the result
without the work around
with the work around
by the way, for the work around i ment "less than" not "bigger than". i will fix it in the discription.
Added subscriber: @scurest
This works for me. To rule out being a formatting issue, can you put a multiply x1000 node in front of the fraction node and check the spreadsheet? If the fraction output is really 0.9997, the multiply will make it 999.700.
Added subscriber: @mano-wii
I'm not seeing a bug here.
For me what is happening is: The numbers in the Spreadsheet interface only have space for 3 decimal places, so, for visualization, it rounds the value.
The actual value is not affected.
