Problem with navigating in 3D view (Or a bug in detecting pressed keys) #98933
5 Participants
Reference: blender/blender#98933
Operating system: Windows 10
Graphics card: RX560
Broken: 3.2.0 (Latest on steam)
Worked: Older version on steam (3.1.0)
I'm using keyboard key 'Q' instead of middle mouse button for panning and rotating in 3D view. so to pan around , I use Shift+Q . Yesterday my blender got updated to the latest stable release (3.2.0) and ever since I'm experiencing a weird problem while pressing and releasing these keys so fast. Sometimes blender doesn't detect these keys when I press and release them so fast. I've installed Screencast keys add-on , and when the problem happens, instead of showing me that I'm holding Shift+Q , It shows that I'm pressing them repeatedly.(see the video)
2022-06-16 15-40-00.mkv
(I've used a keyboard tester to see if the problem is with my keyboard , but my keyboard was ok)
Set up these keyboard shortcuts by clicking on button and pressing key on keyboard:
3DView (Global) Rotate View : Q
3DView (Global) Pan View : W
To trigger the bug:
Now Blender is running
view3d.rotate
operatorAdded subscriber: @Tidominer
Added subscriber: @OmarEmaraDev
I can't replicate that on Linux myself.
Not sure if that would make any difference, but could you try a non-steam version?
Added subscriber: @Bacardi
It would help us to look your problem:
After you edit shortcut keys and you get that "bug" in action. Go to settings, Keymap and upper right corner you see "Export..." button.
You can save Key configuration file (*.py).
Zip and upload that file in here.
This is example. Don't use mine.
Please, dont download this example.zip
*edit
I somehow got that problem.
Windows 10, non-steam version. Blender 3.2.0
Happens when you double tap Q-button (hold last tap some time), then you not move your mouse cursor much from current location. Then next action maybe not work.
With default Key confiqurations, you get Quick Favourites windows with Q button.
I guess, that interfear your shortcut keys. That window disappear after few seconds, before that it cancel your 3D movements.
You can disable or change key binding from Keymap -> Quick Favourites.
But problem maybe still happen, even you disabled that Quick Favourite and
use your Q buttons for Rotate/Pan/Zoom. You maybe want try change Q button to else as well.
Here is the keymap setting if you still need it:
Blender.py
My Quick Favorites is bound to middle click so that can't cause the problem
I thought that another action which uses key 'Q' might be causing the problem, so I disabled all the shortcuts that used the 'Q' key but didn't make any difference and the problem still remains.
The thing is it was ok before the 3.2.0 update. I've been using Blender for like 5 years (since version 2.79) and never had this problem before, and I think it would be a bit hard for me to change my keymap now.
I tried with non-steam 3.2.0 and the problem is still there.
edit : 3.3.0 alpha is the same.
Still can't reproduce the issue with this keymap. I will leave this to someone on the Windows platform.
Can't reproduce either in 3.3 on Windows
Maybe key-configuration of a particular add-on is interfering? Could you disable your active add-ons and try again?
I have tried with a new blender installation (no config ,keymap, addon, etc...) but the problem is there.
I tested on Blender versions 2.93, 3.0, 3.1.0
I changed Rotate View to button Wand Pan View to button R.
All those version have this... "feature" what OP have problem with.
There is slight delay, after releasing first button. Example if you very quickly change to next button, it not recognise it.
Normally I use Blender default keymap (Using mouse middle button for those action), I don't get that OP's problem, because I'm not fast enough to change between those two actions.
And I don't see, this is huge issue. Not sure is problem in hardware.
I use desktop PC, Windows 10
Ryzen 9 5950x + RTX 3090
Microsoft Comfort Curve keyboard 3000 - USB
G-Sync enabled.
Added subscriber: @iss
Just a note, looking at exported keyboard, I am not sure if my steps are same issue as reported originally - in my case
any
event is used in keymap and in keymappress
event is used.Changed status from 'Confirmed' to: 'Resolved'
After 3.2.1 update the problem seems to be gone.
