Trying to add subdiv and crashes #98957
Reference: blender/blender#98957
Operating system: WIN 11
Graphics card: Radeon RX 480
Broken: (example: 2.80,
edbf15d3c0
, master, 2018-11-28, as found on the splash screen) 3.2.0Worked: (newest version of Blender that worked as expected) Unsure - This is the only version I have used.
Following tutorial for Blender Guru - Trying to re-model the sprinkle after the geo nodes section. Either when I add modifier > subdiv > blender crashes. Or clicking to edit mode and adding modifier.
Select obj > switched to edit mode > add modifier > add subdivision modifier = closes application.
Or select obj > add modifier > add subdivision modifier > switch to edit mode = closes application.
Unsure if this is an actual bug or just my hardware.
Added subscriber: @Tephas
Added subscriber: @rjg
Please check with the Task Manager if you are running out of memory. Most likely you are applying the modifier to an already dense mesh and the resulting geometry exceeds the available memory, resulting in Blender being terminated.
Quite sure this is same as in #98813 (Regression: GPU subdivision crash when switched to edit mode)
@Tephas If you are not running out of memory, please check if the crash still occurs in the most recent build of Blender 3.3.0: https://builder.blender.org/download/daily/
