Geometry nodes Volume Cube crashes when volume is zero #99004
Closed
opened 2022-06-20 04:32:42 +02:00 by Rygel · 19 comments
Operating system: Linux 5.10.117-1-MANJARO
Graphics card: AMD ATI Radeon RX 580
Broken: 3.3.0 alpha (since 838c4a97f1)
Sometimes when dragging either of the limits of the node Volume Cube, it will crash when they are equal to each other. Other times, it will correctly report that the volume is zero, avoiding the crash.
  • Open .blend file
  • Select Volume Cube node
  • select all three min input (click and drag down)
  • Type 1.0001 (Will crash)
    Will also crash on dragging all the values of the "min" input until they are at 1.0 (The input must be dragged all at once, or it won't crash)
volume crash.blend
**System Information** Operating system: Linux 5.10.117-1-MANJARO Graphics card: AMD ATI Radeon RX 580 **Blender Version** Broken: 3.3.0 alpha (since 838c4a97f1) **Short description of error** Sometimes when dragging either of the limits of the node Volume Cube, it will crash when they are equal to each other. Other times, it will correctly report that the volume is zero, avoiding the crash. **Exact steps for others to reproduce the error** - Open .blend file - Select `Volume Cube` node - select all three `min` input (click and drag down) - Type 1.0001 (Will crash) Will also crash on dragging all the values of the "min" input until they are at 1.0 (The input must be dragged all at once, or it won't crash) [volume crash.blend](https://archive.blender.org/developer/F13205314/volume_crash.blend)
Author
Added subscriber: @rygelXVI
#100087 was marked as duplicate of this issue
Member
Member
Member
Added subscriber: @lateasusual
Closed as duplicate of #94969
Added subscriber: @dfelinto
Thanks for the report. I'm assuming this was what was fixed on 522dcc54af.
In the future remember to include the hash of the Blender build you used for test (if you report the bug from within Blender it is filled automatically). Otherwise it is hard to tell if it was fixed already.
Thanks for the report. I'm assuming this was what was fixed on 522dcc54af. In the future remember to include the hash of the Blender build you used for test (if you report the bug from within Blender it is filled automatically). Otherwise it is hard to tell if it was fixed already.
Member
Changed status from 'Duplicate' to: 'Confirmed'
Member
Can still repro crash in recent buildbot build. So reopening the ticket :)
(Also I've made some edits in task description)
Can still repro crash in recent buildbot build. So reopening the ticket :) (Also I've made some edits in task description)
Member
Added subscribers: @brecht, @JacquesLucke
Member
Hm, that's annoying, there is an assert in openvdb:
The geometry nodes side feels quite reasonable, not sure if there is really an error in the logic. We could clamp the values on geometry nodes, which would help solve the crash in that specific case (at the cost of a wrong result), but not the more general case. For example, using the Transform node to scale the volume down a lot would still result in this crash. The only real solution I see right now is that we could store a transformation matrix on top of the transform stored in an opengdb grid. @brecht what do you think about that?
Hm, that's annoying, there is an assert in openvdb: ![image.png](https://archive.blender.org/developer/F13318460/image.png) The geometry nodes side feels quite reasonable, not sure if there is really an error in the logic. We could clamp the values on geometry nodes, which would help solve the crash in that specific case (at the cost of a wrong result), but not the more general case. For example, using the Transform node to scale the volume down a lot would still result in this crash. The only real solution I see right now is that we could store a transformation matrix on top of the transform stored in an opengdb grid. @brecht what do you think about that?
An additional transformation matrix I guess will make the API and I/O more complicated? I'm not sure how that would map for renderers, exporters or saving OpenVDB files.
Would it be bad to generate an empty grid with unit scale (maybe keep translation and rotation)? The Transform node could do the same. It's somewhat inconsistent with other geometry types, but if you scale a mesh down to zero with the Transform node it is also effectively destroyed, so I'm not sure it matters much.
An additional transformation matrix I guess will make the API and I/O more complicated? I'm not sure how that would map for renderers, exporters or saving OpenVDB files. Would it be bad to generate an empty grid with unit scale (maybe keep translation and rotation)? The Transform node could do the same. It's somewhat inconsistent with other geometry types, but if you scale a mesh down to zero with the Transform node it is also effectively destroyed, so I'm not sure it matters much.
Member
Member
I agree with Brecht that supporting this case is not worth the complication in other areas. The additional matrix would also have a performance cost when sampling volumes.
I don't have much of an opinion on how to solve this otherwise though. Generating an empty grid seems fine to me.
I agree with Brecht that supporting this case is not worth the complication in other areas. The additional matrix would also have a performance cost when sampling volumes. I don't have much of an opinion on how to solve this otherwise though. Generating an empty grid seems fine to me.
I think an empty grid would be sensible.
Member
Added subscriber: @B2Z
This issue was referenced by e3a6a2f412
This issue was referenced by e3a6a2f41284f90b01065309dbe2cfb97a292b41
Member
Jacques Lucke self-assigned this 2022-08-29 17:00:35 +02:00
Thomas Dinges added this to the 3.3 LTS milestone 2023-02-08 15:37:46 +01:00
8 Participants
Reference: blender/blender#99004
