blender doesnt read NAS #99008
5 Participants
Reference: blender/blender#99008
Operating system: Windows-10-10.0.19042-SP0 64 Bits
Graphics card: NVIDIA GeForce RTX 2080 SUPER/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 511.65
Broken: version: 3.2.0, branch: master, commit date: 2022-06-08 10:22, hash:
e05e1e3691
When opening files NAS is not shown{F13205771}
asset saved on NAS will not load as well
Added subscriber: @Hongyu
I cannot confirm that with Blender 3.2 nor Blender 3.3 Alpha. Works fine here with a NAS drive.
It's important to connect to the drive though, before opening Blender. Unconnected drives are not shown.
Added subscriber: @iss
@Hongyu Please try restarting Blender - does that help?
If not, we will need more information, like model of NAS to check if this is common issue.
I found out this only happens when I run as administrator which is required by some addons like the sketchfab addon
That's interesting, but not sure why that would be an issue. Still I would need NAS model to check its specs. I would assume that it's using some weird API or perhaps you have to configure it to work with all users
the model is qnap ts-1635ax
Thanks for info. I see that NAS does support samba sharing, which I assume you would then configure it as network drive like this:
Can you confirm that your NAS drive has its letter and you see it listed in "This PC"?
yes, i do see it. in my pc and in blender
but when i run blender as administrator i cant see it in blender anymore
Changed status from 'Needs User Info' to: 'Needs Developer To Reproduce'
Added subscriber: @Harley
@Hongyu Thanks for info, I can reproduce this issue when running as admin too. Don't think this could be considered as bug in Blender though. You can follow guide at https://docs.microsoft.com/en-us/troubleshoot/windows-client/networking/mapped-drives-not-available-from-elevated-command to resolve this issue.
@Harley Seems that
GetLogicalDrives()
does not report network drives "correctly" in this case. According to https://stackoverflow.com/questions/42767614/how-to-correctly-detect-network-drive-when-running-with-elevated-privileges it seems like it would be possible to work around, but the code seems a bit magical to me. Do you think this is something you would like to resolve or shall I close this report?@iss - As far as I can tell this isn't really a Blender issue...
If you map a network drive as person A, but then launch the program as person B, you won't see that drive mapping. Not sure that this could even be solved with user tokens since the program running as B doesn't even know who A is.
If I were having this problem I would just make a batch file that:
And then run that batch file as Administrator. Should work perfectly.
You could also just use the UNC patch instead of the drive letter. So if you are mapping
*server/sharename
to toF:
, just copy*server/sharename
into the Blender File Browser location bar, bookmark that.Another (distant) possibility is to show users unmapped network shares: D6802: Test Only: Available Windows Network Shares but the discovery process can take a while on some systems (although almost instant on well-designed large domains).
Added subscriber: @LazyDodo
Blender requires no special permissions there should be no need to run it as administrator, we generally advise against it since it also prevents drag and drop from working from unprivileged processes like explorer
I only run as admin because Sketchfab addon requires it or it won't work correctly
They mentioned that they "run as administrator which is required by some addons like the sketchfab addon". Would make more sense to fix those addons, since that should never be required. Hate to make someone's experience worse - and potentially unsafe - just to accommodate some funky addons.
I wish they can fix it. Reported it long ago on git hub. The developer is very inactive
Changed status from 'Needs Developer To Reproduce' to: 'Archived'
Thank you all for info. Will close this report, since this is not bug in Blender.
