blender freezes at the very start #99025
Reference: blender/blender#99025
Operating system: windows 11
Graphics card: intel uhd graphics
Broken: (example: 2.90,
edbf15d3c0
, master, 2022-6-20, as found on the splash screen)Worked: (until the moment of the problem, everything worked fine)
When running any file, everything works fine, but as soon as I try to perform any action, it freezes and eventually crashes. None of the components of the computer is loaded at this moment and is not under stress.Blender 2022-06-20 21-42-33.mp4
Added subscriber: @gdeto
Added subscriber: @iss
Please check if this happens with alpha build from https://builder.blender.org/download/daily/
At first everything worked fine, but when I went into sculpting mode, everything flew out
Might be same issue as discussed in #86778 (Viewport Slowdown on 11th gen Intel Xe graphics)
@gdeto, please update your iGPU drivers from intel's website and see if that makes any difference: https://www.intel.com/content/www/us/en/support/products/80939/graphics.html
Also: as @iss said, try recent blender versions. 2.90 is not maintained anymore
@gdeto Thanks for checking, can you run file
blender_debug_gpu.cmd
and upload created files after you close or terminate Blender? Also what does "flew out" mean? is it still freezing or some different issue? If this means graphical glitches, can you make short video? You may also try runningblender_debug_gpu_glitchworkaround.cmd
and see if that helps.Don't think it's same as #86778 since they need to wait until RAM is full before freezing, unless @gdeto has like 1.5GB of ram or so. Even then RAM fills relatively slowly in that report.
blender_debug_output.txt
blender_system_info.txt
second part
Blender 2022-06-21 21-34-42.mp4
Blender 2022-06-21 21-39-22.mp4
Thanks for info.
For first video, it may help if you disable GPU subdivision in Preferences > Viewport > Subdivision
As for other problem it seems to be also issue with GPU driver. I am not able to reproduce here. I will try with intel machine, but not sure if specs are similar to your HW. Can you specify what CPU model do you use?
Any updates?
Checked with Blender 3.4.0 and Intel(R) HD Graphics 500, 4.5.0 - Build 27.20.100.8681.
Everything seems to work well.
