Changed behavior of transform operator #99124
5 Participants
Reference: blender/blender#99124
Graphics card: NVIDIA GeForce RTX 2080 SUPER/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 512.15
Broken: version: 3.2.1 Release Candidate, branch: master, commit date: 2022-06-22 11:55, hash:
c5c384d6ea
Worked: version: 3.1.2
Changed behavior of transform operator with 'g' key when using tablet.
What should happen
What happens
Additional notes
Added subscriber: @fatboyzzfatboyzz
Added subscriber: @OmarEmaraDev
I don't think this behavior is unexpected. Once you press the pen on the tablet, you are activating the selected tool, which is the cursor tool in this case, any keys pressed after that are handled by that active tool until it is confirmed.
To confirm, are you saying that this was different in 3.1? Because I can't replicate that myself.
Hi, this behavior is in 3.2. In 3.1 it works fine.
I use this operation to transform object or vertices while pen touching tablet with direct shortcut since roughly 2.8.
But now in 3.2 I have to first switch to one of "Move" "Rotate" "Scale" "Transform" tool instead of keep using the Cursor tool unchanged.
Here are two disadvantages when changing tools.
This is one simple extra step but since I transform a lot. I want the old behavior back.
I still can't replicate that on 3.1 for some reason. Do it still work with a factory reset? File > Defaults > Load Factory Settings.
Broken in 3.2 so replicate in 3.2.
In 3.1 everything works.
I understand, I am try to replicate the good behavior, not the bad. Does the good behavior happen in 3.1 with factory settings in your end?
Okay. I will leave this to someone on a similar platform to triage.
3.1 Good
GOOD_3_1_H.264.mp4
3.2 Bad
BAD_3_2_H.264.mp4
Added subscribers: @PrototypeNM1, @iss
Don't have tablet to check, @PrototypeNM1 can you repro?
Can't reproduce. There were some changes to Wintab button input handling but I don't think they could by themselves cause this behavior.
@fatboyzzfatboyzz Can you run 3.2 from command line with the argument
blender.exe --debug-wintab
, recreate the bug, and copy the command line output here, and link the resulting paste to this report?Also, can you check that your Tablet Preferences utility app isn't set up for custom mouse input in Blender 3.2?
blender-321--debug-wintab-output.mp4
blender-321--debug-wintab-output.txt
I have all software using the same tablet settings.
I am using WACOM CTL-672.
Hi @PrototypeNM1 . I have some ideas about this bug.
To start the transform operation normally in blender 3.1. I have to do the following input.
If I move the pen before pressing 'g'. Transform operation won't start.
Maybe you developers created a new tablet input system which increased the accuracy of tablet input.
So I am not able to press 'g' while not moving the pen.
At last I want to claim that what I need is Transform object while pen touching tablet with Cursor Tool and shortcut 'g'.
Changed behavior of transform operator with tabletto Changed behavior of transform operatorI get it now. This change in behavior is actually unrelated to tablets, you can see the same change in behavior from Blender 3.1 to 3.2 with a mouse.
@OmarEmaraDev I don't think this is a platform issue, since this isn't just a tablet problem and afaik mouse input handling hasn't changed for Windows recently. More likely the transform operator was subtly changed.
Edit: Was the 3D cursor previously transformable?
I am not familiar with tablets, I assumed that only applying certain pressure would register as left click. Not sure if this would be considered as a bug, personally I wouldn't expect to be able to run operator after clicking with tool chosen.
Added subscribers: @ideasman42, @JulienKaspar
This behaviour change in 3,2 is actually due to an improvement to click & dragging that I've discussed with @campbellbarton.
What is happening is that while holding a click, and pressing a shortcut, Blender will immediately execute the operation that would've happened on a click & drag and use the shortcut for that operation.
This made any click & drag operation from using active tools faster and less error prone, because you can already use modal shortcuts of the active tool in between the click and reaching the drag threshold.
So pressing a shortcut no longer results in the wrong operation being applied (or in some cases the operation never getting executed).
So in that case this is not a bug but the intended behaviour.
In the example shown with the 3D cursor, it's correctly executing the cursor tool when click & holding and then pressing G, R or S. Afterwards it is immediately using that shortcut for the modal operation that would've been executed when reaching the drag threshold.
@fatboyzzfatboyzz What I'd like to know is why you are already click and holding with the left mouse button / pen and then pressing
G
? Why not just pressG
?This might just be a workflow issue.
@JulienKaspar About why not just press G.
If we press 'g' before the pen touching tablet, we enter the transform operator, but we have to transform object while pen hovering above the tablet which is very bad for controlling the transform.
I want the transform happens while my pen touching the tablet for precise control.
If I switch to one of "Move" "Rotate" "Scale" "Transform" tool I am able to transform while pen touching tablet but there are two disadvantages when changing tools.
Use the transform gizmo also let me transform while pen touching tablet but this requires me hovering the pen and move the mouse cursor to gizmo first. Much slower than just clicking anywhere press 'g' and do the precise transform.
Removed subscriber: @PrototypeNM1
@fatboyzzfatboyzz This is not how the operators are meant to be used though. This behaviour was only possible for the transform operators before, not any of the other modal operator shortcuts.
But you are free to customise the keymap to your liking. You can change the shortcuts to a "Left Mouse Press" with the
G
key as a modifier key. Then enable "Confirm on release" in the operator settings of the keymap entry.@JulienKaspar
Setting 'g' as modifier key requires first hold the 'g' key then use pen touch the tablet.
Feels weird when the holding key is not 'Ctrl' or 'Shift' like key anyway.
Also I found the select box tool does exactly what I want which do not require any changed settings.
Maybe this behavior is a bug since left click with select box tool did not start box selecting.
Please don't change this select box tool behavior in future.
