Experimental Hair: Spline factor gets messed up if one hair is too short #99130
2 Participants
Reference: blender/blender#99130
Broken: version: 3.3.0 Alpha, branch: master, commit date: 2022-06-24 04:38, hash:
3323cd9c9a
Worked: n/a
Simplified file
The issue happens when one of the hair is very very very very short. In this file the moment the small spline gets shrinked to nothing, the Spline parameter gets broken for the other spline as well.
einar_mustache_factor_reset_2.blend
If you delete the shrinked hair, the other hair goes back to normal.
Complex file
einar_mustache_factor_reset.blend
einar_hair_factor_loss2.mp4
Added subscriber: @dfelinto
Spline factor gets messed up if one hair is too shortto Experimental Hair: Spline factor gets messed up if one hair is too shortAdded subscriber: @JacquesLucke
Removed subscriber: @dfelinto
This is actually a known issue.
The problem is that the Spline Parameter for every control point is ill-defined when all points have the same position. In those example files, that leads to the radii to be 0.0.
That affects the others, because the drawing at the moment can only use the same radius for all curves. Currently, that radius is taken from the first curve (that is arbitrary).
So when the first curve has bad radii, all curves will have bad radii, until the drawing code properly supports a separate radius per curve.
The shrinking tool has an option that prevents this:
Scaling > Minimum Length
setting.Added subscriber: @eyecandy
This issue was referenced by
f1d191120f
