Geometry Nodes: writing attributes (from procedurally created geometry) to vertex groups not working #99197
16 Participants
Reference: blender/blender#99197
Operating system: macOS Monterey 12.4
Graphics card: RX 6800 XT
Broken: 3.1 & newer
Worked: 3.0.1
In Blender 3.0.1, it was possible to write attributes from procedurally created geometry (created by geometry nodes) to vertex groups, as long as the "Group Input" node was joined with the procedural geometry. However, no version newer than 3.0.1 seems to have this capability. From what I understand, this may have been done intentionally in anticipation of attributes replacing vertex groups entirely... but it seems odd to kill this feature before that transition is complete, so I'm reporting this as a bug.
Open the attached .blend file in Blender 3.0.1:
geonodes_attrib_to_vgroup.blend
This file contains a geonodes setup where half of a procedurally generated grid is extruded using a solidify modifier. The "geonodes" object should look exactly the same as the "Expected Result" object.
Next, open the file in Blender 3.3 (or 3.1, or 3.2) and notice how the "Expected Result" object no longer matches the "geonodes" object.
Added subscriber: @JoeyDeutsch
#102516 was marked as duplicate of this issue
#100921 was marked as duplicate of this issue
#101427 was marked as duplicate of this issue
#100948 was marked as duplicate of this issue
#100908 was marked as duplicate of this issue
Added subscriber: @mod_moder
But you have a different problem. You cannot enter a field in a modifier. Use an extrude node. The idea is to work completely only in nodes
I understand that, but I feel that it's a bit shortsighted to remove the ability to write attributes (specifically point float attributes) to vertex groups before that transition is complete. The solidify modifier was just an example I picked to easily & quickly illustrate my point - where I really miss that feature is when I want to create an entirely procedural "pinned" vertex group for a cloth simulation, for example. Sorry for the confusion haha. Take a look at this file:
geonodes_attrib_to_vgroup_cloth.blend
Open this file in 3.0.1, & click play on the timeline. You'll see that the right half of the grid is pinned appropriately. In 3.1+, the cloth simulator just makes the entire object fall, since the pinned group doesn't work anymore.
If this exact feature won't be re-implemented, do you know when the transition away from vertex groups on these modifiers will be complete? I couldn't find any sort of roadmap for that.
This situation doesn't work because the join node internally just makes a new mesh, it doesn't copy the custom data format from the input meshes. And since geometry nodes doesn't create vertex groups, the result is a generic attribute.
In general, modifiers won't be updated to support attributes. Instead, nodes will be added to make the same features available inside of geometry nodes. You can track that progress here: #86839
Many nodes won't correspond exactly to modifiers though, they're often more focused, more like building blocks.
Gotcha. Well I'm very excited for the node takeover!
Added subscribers: @austineberhart, @JacquesLucke, @SteffenD, @PratikPB2123
Added subscriber: @Carl-Olsen
I created this: https://developer.blender.org/T100948 and it was marked as a duplicate. I'm not sure it is an exact duplicate but it does seem to be related. My case only deals with vertex groups not attributes.
My case still works in 3.2.1 but not 3.3.0
I used this all the time for solidify modifiers. Hoping for a fix/workaround
Added subscriber: @rcrandolph
Hey Carl Olsen, I agree using vertex groups with joined geo node geometry is extremely useful. The hacky, buggy, awful work around I've found is to download the source code for Blender, remove the line of code added at https://developer.blender.org/rB5d67b524412d0dab936170eef65c508930ba4c30 "BLI_freelistN(&dst_mesh->vertex_group_names)", and then build a custom version of Blender with this code change. It looks like the update was added to remove crashes when attributes and vertex groups have the same name, which is reasonable. However, the power of being able to combine geometry nodes, vertex groups, and other modifiers is so powerful that I'm willing to manually avoid double naming anything. The crash comes up when, for example, you have a vertex group and color attribute with the same name. Just make sure not to do this and it appears to work great.
Devs, is it possible to, when naming conflicts occur, just disable the join node with a warning? I noticed that there's already a warning system under color attributes when there's vertex groups and colors with the same name, "Warning: Name Collision: group_name" Maybe the join node can be automatically disabled and the same "Name Collision: group_name" warning can come up on the join node when this occurs? It's a pretty easy problem for the user to avoid once the principle is understood, and being able to use vertex groups still is huge. It allows one to use vertex groups with lattices, beveling, advanced solidify modifier options, all kinds of stuff.
I look forward to the day that geometry nodes can fully replicate the other modifiers, but until then, a work around like this would extend Blender capabilities immensely.
I'm actually surprised that change makes it work at all for you. The join geometry node and realize instances node don't create vertex group data at all, so it's not just about name collisions. The issue is that the vertex group storage system just doesn't work at all with the way attributes or geometry nodes are designed.
I mean, I'm surprised too. I don't really understand the complexities deep in the code, but my thought process was basically this:
5d67b52441
5d67b52441
adds two lines of code, one of which appears to remove vertex groups5d67b52441
was made as a fix for #100562, which discovered that the Join Geometry node would cause a crash if a vertex group and color attribute had the same nameI'm posting in this thread as the ones that seemed more related to the problem I'm having got closed and merged into this one, but they might be separate issues. I'm not trying to create Vertex Groups inside geometry nodes, I'm just wanting to be able to use existing Vertex Groups after using a Join Geometry node. #100908 has a .blend file that demonstrates the issue, but I'll include another one to make it more clear.
join_geometry_version_bug.blend
In the included file, the Vertex Groups are empty by default, and I am editing their weights after a Join Geometry node using the Data Transfer modifier. In 3.2 this works great, and even allows me to add Vertex Group data to a cube generated with the add cube node (listed as a viable work around at #92948.) In Blender 3.3+ this type of functionality is no longer possible. The Data Transfer modifier no longer can edit Vertex Group weights, and it and subsequent modifiers behave as though the Vertex Groups are deleted entirely after a Join Geometry node. I'd much rather use Geometry Nodes for everything than use Vertex Groups and subsequent modifiers, but my current project requires lattices and I fear lattices are not a high priority for Geometry Node integration. Love the work you're all doing, just trying to use it all as soon as possible.
If you do a boolean operation on a mesh vertex group data is kept intact. It would make sense for join geometry to do the same I think. There must be a better way to handle attribute name collisions than this.
Added subscribers: @nacioss, @persun, @OmarEmaraDev
Added subscribers: @BlenderAmateur, @mano-wii
Added subscriber: @GaryRitchie
Added subscriber: @SergeL
Added subscriber: @shadow_creeper
Added subscriber: @MMMM
Thanks. I need vertex weights, for my procedurally generated model, to apply an armature. It's a shame they broke it and seem unwilling to fix it with such a simple fix. :(
I have a really nice model rigged in 3.2 that outright breaks in 3.4, as all the vertex groups have no values any more. :(
Added subscriber: @JacobMerrill-1
A temp workaround would be to copy the data from the evaluated mesh, and then write it to a copy of the mesh without geometry nodes using python.
(if you need this for a production etc)
if you need it to update each frame consider a modal operator*
Great minds think alike! I tried making a script to edit the vertex groups from the attributes, but found out the Geo-nodes models are completely detached from vertex groups.
I didn't think about making a copy.
Instead of making an entirely new object in python, I'd like to using an existing object and copy the evaluated data to the base mesh of the new existing model. Is there a simple command to do this? Like have two objects selected, the first being the geo-nodes object, the 2nd being a blank (or default cube) and copy evaluated data from 1st to base mesh of 2nd?
You mentioned modal operator for frames. This would be great for polymorphing during animations. I know a tiny amount about Blender's python, but not enough get this done in a reasonable amount of time.
Again, I can't thank you enough. I've been working on this project for 6 months, 10+ hours every day, when 3.0 came out. Any and all help to push forward is greatly appreciated.
Added subscriber: @raincole
That's... quite bad. It rules out the most usage of geometry nodes, at least for me.
I found a less than stellar work around.
Instead of using "Join geometry", one can use "Mesh Boolean: Union".
Requirements to transfer vertex groups to Geo-nodes portion:
A: Mesh Boolean has have original geometry as top input, only needs a single vertex
B: Store named attribute must come after Mesh boolean operation
C: There must be no "Join Geometry" After the Mesh Boolean, as this breaks it entirely
Confirmed working in 3.4.1 and 3.6 Alpha (April 7th build)
The reason I call it less than stellar... Mesh Boolean is insanely slow relative to join geometry. Compute time for a 100% procedurally built humanoid: 80ms, compute time of JUST the mesh boolean of adding just a single vertex 30ms VS Join and Merge by distance of <.1ms.
Soooo... what do we need to upvote in order to get them to fix it?
I started experimenting with creating a humanoid with geo nodes and got stuck trying to output vertex groups for the armature modifier only to later realize that it's impossible in 3.6.
And I saw Armature mentioned at #86839
But it looks like it's not gonna happen anytime soon. Very sad state indeed.
Anyone know of a better solution please lemme know.
Is it possible to add a Modifier, which copies a attribute and saves it to a Vertex Group?
Or have a Node, which explicitly saves the values as VertexGroup?
I'm a programmer myself, but haven't coded anything for blender (yet). If someone has done something in these ways i'm happy to help as much as i can. But I don't have an overview and know, if it's even possible...
It is possible to convert attribute to vertex group via Python or Animation Nodes, but it requires object's full copy with applied modifier stack, where this VG will be assigned. And if you also have instances inside object, then this approach won't work, I guess.
This makes geometry nodes pretty much impossible to use with armatures, which is IMO a pretty big issue seeing as armatures are pretty special from an export standpoint.
