CTRL + SHIFT + T Node Wrangler Hot Key does not work. #99225
Open
opened 2022-06-28 01:23:39 +02:00 by Animation Entertainment · 23 comments
Operating system: Windows-10-10.0.19044-SP0 64 Bits
Graphics card: NVIDIA GeForce RTX 3090/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 512.15
Broken: version: 3.1.2, branch: master, commit date: 2022-03-31 17:40, hash: blender/blender@cc66d1020c
Worked: I have never used this hot key before but I have seen videos with it being used.
Addon Information
Name: Node Wrangler (3, 38)
Author: Bartek Skorupa, Greg Zaal, Sebastian Koenig, Christian Brinkmann, Florian Meyer
[CTRL + SHIFT +T doesn't work when all the keys are pressed with the default Principled BSDF Material Node selected.]
  1. Open Blender 3.1.2
  2. Add a mesh which a material may be added onto and select the mesh
  3. Open Shader Editor
  4. Create a new material
  5. Select the Principled BSDF which appears and press CTRL + SHIFT + T
**System Information** Operating system: Windows-10-10.0.19044-SP0 64 Bits Graphics card: NVIDIA GeForce RTX 3090/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 512.15 **Blender Version** Broken: version: 3.1.2, branch: master, commit date: 2022-03-31 17:40, hash: `blender/blender@cc66d1020c` Worked: I have never used this hot key before but I have seen videos with it being used. **Addon Information** Name: Node Wrangler (3, 38) Author: Bartek Skorupa, Greg Zaal, Sebastian Koenig, Christian Brinkmann, Florian Meyer **Short description of error** [CTRL + SHIFT +T doesn't work when all the keys are pressed with the default Principled BSDF Material Node selected.] **Exact steps for others to reproduce the error** 1. Open Blender 3.1.2 2. Add a mesh which a material may be added onto and select the mesh 3. Open Shader Editor 4. Create a new material 5. Select the Principled BSDF which appears and press CTRL + SHIFT + T
Added subscriber: @animation.entertainmenttv
Added subscriber: @deadpin
I am unable to reproduce the issue here. Can you verify that the Node Wrangler addon is actually enabled? Do any other key combinations work?
The Node Wrangler Add on Is enebled.
All the other hot keys are working. I use CTRL + T often and it has always worked.
The Node Wrangler Add on Is enebled. All the other hot keys are working. I use CTRL + T often and it has always worked.
Can you check the following:
  • Execute File -> Defaults -> Load Factory Settings
  • Then Enable only the node wrangler addon
  • Does the key combination work at this point?
Can you check the following: - Execute File -> Defaults -> Load Factory Settings - Then Enable *only* the node wrangler addon - Does the key combination work at this point?
I just tried that and it still doesn't work.
However, CTRL + T does work.
I just tried that and it still doesn't work. However, CTRL + T does work.
Will set back to Needs Triage in hopes that others might be able to take a look here.
OK, thanks Jesse.
OK, thanks Jesse.
Member
Added subscriber: @OmarEmaraDev
Member
Member
Can you check if the keymap existing in the preferences?
Can you open the Blender console and see if there are any error messages when you press the shortcut? Window > Toggle System Console.
Can you check if the keymap existing in the preferences? Can you open the Blender console and see if there are any error messages when you press the shortcut? Window > Toggle System Console. ![20220705-141051.png](https://archive.blender.org/developer/F13260840/20220705-141051.png)
Hey Omar Emara, the keymap is enabled in the preferences. Also nothing new appears in the CMD Console when I initiate the hotkey.
Hey Omar Emara, the keymap is enabled in the preferences. Also nothing new appears in the CMD Console when I initiate the hotkey. ![CTRL_SHIFT_T.png](https://archive.blender.org/developer/F13261181/CTRL_SHIFT_T.png)
Member
Member
Member
Member
@animation.entertainmenttv hi, please attach userprefs.blend file (default location is: C:\Users\user_name\AppData\Roaming\Blender Foundation\Blender\3.1\config)
@animation.entertainmenttv hi, please attach `userprefs.blend` file (default location is: `C:\Users\user_name\AppData\Roaming\Blender Foundation\Blender\3.1\config`)
@PratikPB2123 Surely, here you go.
userpref.blend
@PratikPB2123 Surely, here you go. [userpref.blend](https://archive.blender.org/developer/F13308122/userpref.blend)
Member
Thanks for the file. What exactly is the issue you're experiencing?
  • file browser is not opening after pressing keys? This is likely to happen due to key conflicts
  • or you're having issues in texture setup (after selecting textures)?
Thanks for the file. What exactly is the issue you're experiencing? - file browser is not opening after pressing keys? This is likely to happen due to key conflicts - or you're having issues in texture setup (after selecting textures)?
The problem is CTRL + SHIFT +T hotkey doesn't work when all the keys are pressed using a default Principled BSDF node.
@PratikPB2123 I can't attach multiple textures simultaneously by initiating the hotkey "CTRL + SHIFT +T". All the other other hot keys work just as they should.
Member
Reference: blender/blender-addons#99225
