Animated Holdout & Shadow do not update in Cycles #99450
6 Participants
Reference: blender/blender#99450
Animated holdout and shadow catcher properties do not update when rendering in Cycles. Change frames in the following file, the holdout state of the object should change but will not until the user manually changes any property in the object.
animatedHoldout.blend
Original Report
Operating system: MacOS Monterey
Graphics card: Apple M1 Max
3.2 - (also tried 3 & 2.9)
I'm rendering a product shot for a client that wants the shadows as a seperate file. I animated 2 frames in my blender file. Frame one is the product and the "ground plane" is set as holdout. Frame 2 has the product as holdout and the ground plane as a shadow catcher. The reason i've set it up animated is the output files are HUGE resolution and i'm rendering it all on blendergrid.
This solution worked until a couple of months ago I upgraded to a M1 macbook pro and now the animations don't work - they don't even preview properly in blender. Sometimes the ground plane is visible despite it being set as either holdout or shadow catcher. The products sometimes holdouts when it should appear and sometimes it stays the same for both frames. I've tested it on blendergrid with a small output - it seemed to replicate the problem.
I also tried on 2 older versions of blender and re-animated the holdout / shadow catcher setting to no avail.
MMMilk_Endorphone_cards_170x170.blend
attached .blend file (as simple as possible).
Added subscriber: @MMMilk
....seems to work in 2.92.
no luck with other versions though
Added subscriber: @OmarEmaraDev
In the attached file, the RNA paths of the animation are set to
cycles.is_shadow_catcher
andcycles.is_holdout
, and it seems the API changed and the properties are now part of the ID directly, so you should remove thecycles.
prefix from the path in order for the animation to work again. That might indicate that versioning does not exist for this change.Changed status from 'Needs User Info' to: 'Confirmed'
Looks like versioning for animations is not available indeed.
Changed status from 'Confirmed' to: 'Needs User Info'
But you say this also happens in 2.9, so there might be an issue other than versioning here.
yes the original file didn't work past 2.92
I did also clear the animation keys in 3.2 and reanimated the holdout / shadow catcher check boxes and still had inconsistent results
Could you attach the files after you cleared and reanimated the animation keys? I did the same but can't seem to replicate the issue.
MMMilk__cards_170x170_b3.2_test.blend
Animating Holdout & Shadow catcher not working (cycles)to Animated Holdout & Shadow do not update in CyclesAdded subscribers: @Sergey, @brecht, @LukasStockner
The problem here appears to be that the Holdout control is handled through the view layer system - to be precise,
layer_collection_objects_sync
. This gets called from the RNA update handler of the holdout property, but that doesn't get called for animated properties on frame change of course.I guess a simple fix would be to call
BKE_layer_collection_sync
before rendering? That seems like a hack though, I feel like there should be a cleaner way to handle this update.cc @brecht and @sergey.
@LukasStockner I think we should remove handling of the object holdout settings from layer collection sync, and instead wrapper access to it in a function that checks both the base flag and the object flag.
At some point it would be good to integrate layer collection sync better with the depsgraph, but I wouldn't get into that for this bugfix.
Added subscriber: @KamilD
Hello.
I have the same issue with one of my scene.
holdout is not animated.
Is there any solution for it ? I really need this funkcionality.
probably I could use blender 2.92 but cycles is more faster in 3.3
This issue was referenced by
1492f566c8
b898330c37
