GPencil: Fill tool on the surface will not be fill in correct place. #99459
5 Participants
Reference: blender/blender#99459
Operating system: Windows 10
Graphics card: GTX1080
Broken: 3.2.0, 3.3.0-alpha+master.6e879c39987c
Worked: 2.93.109
The use of the fill tool on the surface of the grease pencil will not be fill in correct place.
Added subscriber: @umiyuki
Added subscriber: @antoniov
Looking at the code, not sure we can solve this easily. The fill tool is working in an "internal" 2D flat representation of the fill area and cannot access to the surface. Also, the fill tool is not designed to work in areas with volume (not flat), so the result can be unexpected.
I would consider this a know issue because the right (a maybe unique) way of solve this is the right way is to have boolean operations. There were some plans about this boolean library for 2D, but now is paused.
The use of the fill tool on the surface of the grease pencil will not be fill in correct place.to GPencil: Fill tool on the surface will not be fill in correct place.Changed status from 'Confirmed' to: 'Needs Developer To Reproduce'
I don't think this is a known issue. It works fine with Blender 2.93 and 3.0. I'm having problems with 3.1 and later. In other words, it's a bug that was recently caused by some mistake.
Added subscriber: @OmarEmaraDev
@OmarEmaraDev I guess this could be introduced in this commit: https://developer.blender.org/rBaa0ac0035a0d3601672a0c732e3f8f932a36fc04
I have tried to compile several times but I cannot compile that version...could you try to find if this commit breaks the fill. In theory, previous commit must work.
Here a simple test file.
T99459_test_file.blend
Added subscriber: @mano-wii
@mano-wii could you try to test this bug? I always get a cmake error with the suspicious commit.
Changed status from 'Needs Developer To Reproduce' to: 'Confirmed'
@mano-wii I have done a partial revert to test and without this commit the fill is working as expected, so something in the depths array is not working as expected in Fill.
This issue was referenced by
703dff333c
Thanks for your efforts to investigate and fix the bug!
