Discrepancy in Cycles rendering result appears when "Pack Resources" on tga file #99565
5 Participants
Reference: blender/blender#99565
Graphics card: Quadro RTX 3000 with Max-Q Design/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 516.25
Broken: version: 3.3.0 Alpha, branch: master, commit date: 2022-07-08 16:07, hash:
2ee6891728
Worked: 3.2.1 release
The 3.3 Alpha version has a trouble to correctly render the tga texture, unless it is packed into the blend file.
After packing the external tga file, the rendering result becomes correct (see above).
1, Open the sample file and load the tga texture;
2, File -> External Data -> Pack Resources;
3, File -> Save as;
4, Open the new saved file
The tga file and the sample Blender file are included.
Should not shine_3.blend
Added subscriber: @Stay_Here
#101810 was marked as duplicate of this issue
Discrepancy appears when "Pack Resources" on tga fileto Discrepancy in Cycles rendering result appears when "Pack Resources" on tga fileAdded subscriber: @EAW
I can confirm that the issue occurs in 3.3 master hash:
443690604f
3.2.1 is ok.
Packed on the left, not packed on the right.
Added subscriber: @LukasStockner
Caused by
33f5e8f239
.Added subscriber: @brecht
This is due to how OIIO's Targa loader is implemented.
In particular, it has an internal "alpha type" that it tries to read from the file. OIIO's internal alpha conversion logic applies whenever the file is 32bpp, it is not explicitly deactivated, and the file's alpha type is not explicitly set to "premultiplied". All three used to be the case for this file, until the commit linked above disabled OIIO conversion.
Instead, Cycles checks the
oiio:UnassociatedAlpha
spec return from OIIO now. Unfortunately, the Targa loader only sets this if the file is 32bpp and the alpha type is set to "useful". So, if the alpha type is neither "premultiplied" nor "useful", there is a change in behavior - the OIIO-internal conversion would have taken place, but the Cycles-side conversion won't.See https:*github.com/OpenImageIO/oiio/blob/c2ed61bb853b4a446f74321c2fe4d665c01ef316/src/targa.imageio/targainput.cpp#L274 vs. https:*github.com/OpenImageIO/oiio/blob/c2ed61bb853b4a446f74321c2fe4d665c01ef316/src/targa.imageio/targainput.cpp#L837.
Apparently, the
logic was changed here , but not the internal logic.@brecht, since I see that you worked on that logic in the past - would you consider this an OIIO bug?
This looks like an OIIO bug to me, I would expect the internal logic and
to match.Added subscribers: @MeshVoid, @mano-wii
This issue was referenced by
94ec66c2f2
0a35afbf86
I committed a workaround, though would still like to have a fix upstream as well. The issue is that it seems seems to have been an intentional change. Probably for files with the same alpha metadata as the files reported here, but different contents, and there may not be a single solution that handles all files correctly.
At least for us consistency with Blender image loading is most important.
