OBJ file doesn't import and ends with error message #99660
Blender Cloud
Documentation
Eevee & Viewport
Import and Export
Rendering & Cycles
Add-ons (BF-Blender)
Add-ons (Community)
Reference: blender/blender-addons#99660
Operating system: Windows 10 21H2
Graphics card: NVIDIA GeForce GTX 1650
Broken: 2.79 (sub 0), branch: master, commit date: 2017-09-11 10:43, hash: 5bd8ac9
Worked: none, only tried 2.79
I was trying to import this one specific obj file I exported from Marvelous Designer but it doesn't import and instead results in an error message in blender. Other obj files have been working but not this one for some reason.
The error message in question (couldn't figure out how to copy the error message directly into here):
mima4.obj
Exactly as how you would import any obj file: Files, Import, click Waveform (.obj), and then go the location of the downloaded obj file, and try to import it.
Added subscriber: @udahn
Added subscriber: @scurest
2.79 won't get bugfixes anymore, but this works with the new OBJ importer in current 3.3 alpha. (Make sure you don't use the importer that says "(legacy)" because it's the same as in 2.79.)
The relevant part of the OBJ appears to be
This is not valid according the OBJ spec btw. Of
curv u0 u1 v1 v2 ...
it says "v is the vertex reference number for a control point. [...] A minimum of two control points are required for a curve."Added subscriber: @PratikPB2123
Thanks for the report.
As @scurest said, new importer imports your obj scene without any error. So please try that (get the latest builds from https://builder.blender.org/download/daily)
However problem remains in the old python importer.
@scurest , btw this is what I see in obj file (when I open it in notepad)
@PratikPB2123 There are several curves in the file. That one (line 97353) is okay. The one I'm talking about is at line 97160. If you comment out lines 97158-97162 the import succeeds.
Is the Python addon still going to get bugfixes? How does that work?
yes, that worked.
Thanks for clarifying :)
I've asked about this in #blender-triaging channel
Added subscriber: @aras_p
The file imports correctly with the new 3.2+ OBJ importer. The Python based one will be removed soon, and meanwhile is very unlikely to get fixes. The file in question is technically invalid, i.e. the curve definition statement is not following the spec.
