Sculpt Paint: Accumulative Painting/Sculpting #99773
Open
opened 2022-07-16 18:11:23 +02:00 by Julien Kaspar · 3 comments
Member
NOTE: This design is still under discussion and is incomplete.
The recent addition of painting tools in sculpt mode also added an alternative design for accumulative painting.
Because of this there are now two different ways of handling accumulative strength.
This needs to be polished and properly integrated into the UI and painting workflow.
Strength and Accumulate
So far brushes always had an "Accumulate" setting for removing the maximum strength cap. Brushes would then keep adding their effect as long as the stroke continues.
Otherwise they would either accumulate up to a hard-coded upper strength cap (sculpt mode) or up to the set strength (painting modes).
The issues with this implementation are:
  • It is easy to accidentally clip the colors while painting (There is no upper cap with accumulate)
  • The setting is hidden in "Advanced" brush settings even though it is regularly used, and even preferred for painting.
Flow
The new painting brush in sculpt mode instead uses a "Flow" slider, which defines how strong each step of the stroke is.
The stroke will then keep accumulating more slowly towards the set Strength.
There are a few issues with this implementation:
  • The Flow setting is less accessible, even though it can sometimes to be the preferred way of changing the stroke intensity.
  • The relationship between Strength and Flow becomes very confusing, especially when comparing sculpting & painting brushes or when enabling pressure sensitivity settings
Proposal
How to make the settings and behaviours more predictable and accessible needs to be further discussed.
NOTE: This design is still under discussion and is incomplete. The recent addition of painting tools in sculpt mode also added an alternative design for accumulative painting. Because of this there are now two different ways of handling accumulative strength. This needs to be polished and properly integrated into the UI and painting workflow. # Strength and Accumulate So far brushes always had an "Accumulate" setting for removing the maximum strength cap. Brushes would then keep adding their effect as long as the stroke continues. Otherwise they would either accumulate up to a hard-coded upper strength cap (sculpt mode) or up to the set strength (painting modes). The issues with this implementation are: - It is easy to accidentally clip the colors while painting (There is no upper cap with accumulate) - The setting is hidden in "Advanced" brush settings even though it is regularly used, and even preferred for painting. # Flow The new painting brush in sculpt mode instead uses a "Flow" slider, which defines how strong each step of the stroke is. The stroke will then keep accumulating more slowly towards the set Strength. There are a few issues with this implementation: - The Flow setting is less accessible, even though it can sometimes to be the preferred way of changing the stroke intensity. - The relationship between Strength and Flow becomes very confusing, especially when comparing sculpting & painting brushes or when enabling pressure sensitivity settings # Proposal How to make the settings and behaviours more predictable and accessible needs to be further discussed.
Author
Member
Author
Member
Added subscribers: @JulienKaspar, @JosephEagar, @Jeroen-Bakker, @Limarest, @DanielBystedt
Member
I actually added the normal accumulation mode to sculpt-dev. I originally didn't port it to master due to bugs, though I think they've all been fixed now. I think both modes make sense, so we should port it over to master.
Julien Kaspar added this to the Sculpt, Paint & Texture project 2023-02-08 10:20:48 +01:00
Philipp Oeser removed the
label 2023-02-10 09:11:14 +01:00
2 Participants
Reference: blender/blender#99773
