Geomtetry Nodes: Fillet Curve wrong radius with one switch option being 0 #99889
Closed
opened 2022-07-21 15:33:43 +02:00 by D0ppelgaenger · 12 comments
Operating system: Windows-10-10.0.22000-SP0 64 Bits
Graphics card: NVIDIA GeForce RTX 3070/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 516.59
Broken: version: 3.3.0 Alpha, branch: master, commit date: 2022-07-20 22:17, hash: 9f68369247
Worked: 3.3.0 Alpha from yesterday (21/07/2022)
Wrong radius result if one of the options of a switch node is equal to 0.
Even tough the result of the switch is true for all points, sometimes it still does not use the True value, or the other way around (if False >0 and True=0)
It must have to do with Port fillet node to the new data-block , since in yesterday's daily build it worked fine.
Hope I described it in a way that makes sense
Open example file
Connect different values to Viewer Socket of the node output
See that, e.g. radius should be 2. Yet if the fillet node evaluates it, it reads 0 for some points
FilletBug.blend
**System Information** Operating system: Windows-10-10.0.22000-SP0 64 Bits Graphics card: NVIDIA GeForce RTX 3070/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 516.59 **Blender Version** Broken: version: 3.3.0 Alpha, branch: master, commit date: 2022-07-20 22:17, hash: `9f68369247` Worked: 3.3.0 Alpha from yesterday (21/07/2022) **Short description of error** Wrong radius result if one of the options of a switch node is equal to 0. Even tough the result of the switch is true for all points, sometimes it still does not use the **True** value, or the other way around (if False >0 and True=0) It must have to do with [Port fillet node to the new data-block ](https://developer.blender.org/rB2551cf908732bab2865654571164d74e8bbad47e), since in yesterday's daily build it worked fine. Hope I described it in a way that makes sense ![RadiusAfterSwitch_FalseEqualZero.png](https://archive.blender.org/developer/F13306127/RadiusAfterSwitch_FalseEqualZero.png) ![RadiusAfterSwitch_FalseNotEqualZero.png](https://archive.blender.org/developer/F13306126/RadiusAfterSwitch_FalseNotEqualZero.png) **Exact steps for others to reproduce the error** Open example file Connect different values to **Viewer** Socket of the node output See that, e.g. radius should be 2. Yet if the fillet node evaluates it, it reads 0 for some points [FilletBug.blend](https://archive.blender.org/developer/F13306688/FilletBug.blend)
Author
Added subscriber: @Leo-Luther
Member
Added subscriber: @OmarEmaraDev
Member
Member
I can reproduce the issue. The index of the control point in the pre-beveled curve is 16.
Can you try to simplify the file though to make it easier to debug this?
I can reproduce the issue. The index of the control point in the pre-beveled curve is 16. Can you try to simplify the file though to make it easier to debug this?
Omar Emara changed title from Geomtetrynodes: Fillet Curve wrong radius with one switch option being 0 to Geomtetry Nodes: Fillet Curve wrong radius with one switch option being 0 2022-07-21 16:34:11 +02:00
Author
I already removed a tone of nodes and don't know how much more I could take away.
Nodes outside the node group
  • You can take away the random set cyclic, and it seems that the issue only seems to appear on non-cyclic splines.
  • It also only happens if the splines have different points and are not uniform, therefore the resample random count is needed.
  • The nodes that follow the G_Fillet Curve node group can in theory be removed and only serve the purpose of better visualizing the bug
Nodes within the node group
  • The capture attribute can be removed and was only added to make sure that the issue is definitely not due to a mistake with evaluating the angel at the wrong position
  • I'd like to remove more nodes inside the group and find another switch condition for which the issue appears, but I haven't found one yet.
I know that it therefore might seem like the issue lies somewhere else (point angle node group or so), but it worked before the port to the new data block from yesterday
  • Also, if you view the values in the spreadsheet they are correct (example: point of the original curve with index 12 shows a value of 2, however the fillet still fillets with a radius of 0)
  • Also, if you change the False value to even just 0.000001 it suddenly works as expected (which indicates that it is an issue with the switch being set to 0)
Reduced File 2 comments down
I already removed a tone of nodes and don't know how much more I could take away. Nodes outside the node group - You can take away the random set cyclic, and it seems that the issue ***`only seems to appear on non-cyclic splines`***. - It also only happens if the splines have different points and are not uniform, therefore the resample random count is needed. - The nodes that follow the **G_Fillet Curve** node group can in theory be removed and only serve the purpose of better visualizing the bug Nodes within the node group - The capture attribute can be removed and was only added to make sure that the issue is definitely not due to a mistake with evaluating the angel at the wrong position - I'd like to remove more nodes inside the group and find another switch condition for which the issue appears, but I haven't found one yet. ``` I know that it therefore might seem like the issue lies somewhere else (point angle node group or so), but it worked before the port to the new data block from yesterday ``` - Also, if you view the values in the spreadsheet they are correct (example: point of the original curve with index 12 shows a value of 2, however the fillet still fillets with a radius of 0) - Also, if you change the False value to even just 0.000001 it suddenly works as expected (which indicates that it is an issue with the switch being set to 0) Reduced File 2 comments down
Added subscriber: @mod_moder
For example, all of this
Just create new project and do bug by 5-10 nodes
I still don't understand what is wrong
![image.png](https://archive.blender.org/developer/F13306433/image.png) For example, all of this Just create new project and do bug by 5-10 nodes I still don't understand what is wrong
Author
Sry wasn't aware, that all of that old stuff was still there (was too zoomed in and didn't see it)
Here I removed it
FilletBug.blend
The issue is that even though the result for the radius coming from the switch node is 2 (as you can see in the spreadsheet) the actual fillet is done with a value of 0 (resulting in no fillet at all)
Sry wasn't aware, that all of that old stuff was still there (was too zoomed in and didn't see it) Here I removed it [FilletBug.blend](https://archive.blender.org/developer/F13306687/FilletBug.blend) The issue is that even though the result for the radius coming from the switch node is 2 (as you can see in the spreadsheet) the actual fillet is done with a value of 0 (resulting in no fillet at all)
2022-07-21 21-49-18.mp4
Is there an error here?
[2022-07-21 21-49-18.mp4](https://archive.blender.org/developer/F13306701/2022-07-21_21-49-18.mp4) Is there an error here?
Author
Index 6/7 are endpoints, so they are supposed to be 0/False
Index 11/12 however, aren't endpoints, their switch condition is True and the switch therefore outputs 2 as value as seen in this screenshot (so far working as expected). However, the value these two points actually get filleted with is 0.
Also, as soon as you change the False result of the switch (even if just 0.00001) it suddenly fillets with the value you set for True (2 in this case)
Index 6/7 are endpoints, so they are supposed to be 0/False Index 11/12 however, aren't endpoints, their switch condition is True and the switch therefore outputs 2 as value as seen in this screenshot (so far working as expected). However, the value these two points actually get filleted with is 0. ![image.png](https://archive.blender.org/developer/F13306745/image.png) Also, as soon as you change the **False** result of the switch (even if just 0.00001) it suddenly fillets with the value you set for **True** (2 in this case)
This issue was referenced by 5feb3541f4
This issue was referenced by 5feb3541f459d916202b705c2e9c62f5778e182b
Member
Jacques Lucke self-assigned this 2022-07-25 12:22:05 +02:00
5 Participants
Reference: blender/blender#99889
