Blender Studios blender_svn plugin does not show UI in Mac M1 USD build #99899
Closed
opened 2022-07-22 03:22:40 +02:00 by Eliot Mack · 13 comments
Operating system: MacOS Big Sur
Graphics card: Mac Mini M1 16GB
Broken: 3.3.0 Alpha Apple Silicon Universal-Scene-Description
(example: 2.79b release)
I installed the Blender Studio blender_svn add-on, and saved a .blend file into a directory that is part of a Subversion repository. The 'SVN' UI panel did not appear.
Install blender_svn add-on, then save a .blend file in a directory that is part of a Subversion repository. The Blender UI should change to include a 'SVN' tab on the right of the viewport, but no change occurs.
**System Information** Operating system: MacOS Big Sur Graphics card: Mac Mini M1 16GB **Blender Version** Broken: 3.3.0 Alpha Apple Silicon Universal-Scene-Description (example: 2.79b release) (example: 2.80, edbf15d3c044, blender2.8, 2018-11-28, as found on the splash screen) Worked: (optional) **Short description of error** I installed the Blender Studio blender_svn add-on, and saved a .blend file into a directory that is part of a Subversion repository. The 'SVN' UI panel did not appear. **Exact steps for others to reproduce the error** Based on the default startup or an attached .blend file (as simple as possible). Install blender_svn add-on, then save a .blend file in a directory that is part of a Subversion repository. The Blender UI should change to include a 'SVN' tab on the right of the viewport, but no change occurs.
Author
Added subscriber: @Eliot-Mack
Member
Added subscriber: @OmarEmaraDev
Member
Member
Just to double check, did you enable the add-on after installing it? If yes, can you check if there are any errors when opening Blender from the terminal when you try to navigate to the SVN tab?
Author
I enabled it in the Preferences/Add-ons window. (Had to re-zip the folder on the Mac so the Blender installer could see the expected zip file. )
I set up the Mac build to start up with a console window, and rebooted the machine, and the SVN panel is appearing. Go figure. I'm not sure which of those two did the trick; guessing it was the reboot.
I'll start working with it. Thanks!
  • Eliot
I enabled it in the Preferences/Add-ons window. (Had to re-zip the folder on the Mac so the Blender installer could see the expected zip file. ) I set up the Mac build to start up with a console window, and rebooted the machine, and the SVN panel is appearing. Go figure. I'm not sure which of those two did the trick; guessing it was the reboot. I'll start working with it. Thanks! - Eliot
Author
An update -- the SVN Files window shows up, but I never see the window show up with a file tree, as shown in the video:
Author
![nosvnwindow.JPG](https://archive.blender.org/developer/F13308588/nosvnwindow.JPG)
Added subscriber: @mano-wii
Changed status from 'Needs User Info' to: 'Resolved'
Germano Cavalcante self-assigned this 2022-07-22 21:05:27 +02:00
-Eliot
In this case, I'm considering the issue resolved then, although we don't know really the cause.
The other questions seem to be support requests so I suggest try one of the community websites: https://www.blender.org/community/
> In #99899#1394226, @Eliot-Mack wrote: > > I enabled it in the Preferences/Add-ons window. (Had to re-zip the folder on the Mac so the Blender installer could see the expected zip file. ) > > I set up the Mac build to start up with a console window, and rebooted the machine, and the SVN panel is appearing. Go figure. I'm not sure which of those two did the trick; guessing it was the reboot. > > I'll start working with it. Thanks! > > -Eliot In this case, I'm considering the issue resolved then, although we don't know really the cause. The other questions seem to be support requests so I suggest try one of the community websites: https://www.blender.org/community/
Author
Please look at the most recent note -- the SVN tab shows up, but I never see a window show up with the file tree as in the example video.
This isn't resolved yet.
Please look at the most recent note -- the SVN tab shows up, but I never see a window show up with the file tree as in the example video. This isn't resolved yet.
Member
This file explorer was most likely opened using a shortcut of the desktop environment, it is not related to the add-on.
Author
OK thanks.
OK thanks.
Reference: blender/blender-addons#99899
