Can not get eval obj's attribute in get/set function #99964
Reference: blender/blender#99964
Operating system: Windows-10-10.0.22000-SP0 64 Bits
Graphics card: NVIDIA GeForce RTX 2080 SUPER/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 512.96
Broken: version: 3.3.0 Alpha, branch: master, commit date: 2022-07-24 19:33, hash:
6db059e3d7
Worked: 3.2.1 / 3.3.0 7-10 build
2022-07-25 18-23-39.mp4
when using this script to get object's attribute in a property's get/set function, it didn't work
I need some time to clean up the code and upload the smallest file
Added subscriber: @1029910278
Added subscriber: @mano-wii
Thanks for the report, but in order to forward it to the developers, we need a reliable way to reproduce the issue.
So please provide a simple .blend file or script showing the problem.
A guideline for making a good bug report can be found at https://wiki.blender.org/wiki/Process/Bug_Reports
The first test file from my code. I am not sure it cause this error directly, it work fine in my addon but crash blender when select a object(to read its attribute) here
ERROR (bpy.rna): C:\Users\blender\git\blender-vdev\blender.git\source\blender\python\intern\bpy_rna.c:7392 pyrna_srna_Subtype: failed to register 'Attribute'
Reproduce
get_geo_obj_attr.blend
get_geo_obj_attr.crash.txt
I will write a get/set examle later
The second file, this is how it work get_geo_obj_attr2.blend
PS: I set the depsgragh to a global value becauese I found that if I call 2 context.eval_depsgraph_get at a same time will freeze blender forver (like 2 drawing function call at the same time)
Added subscriber: @OmarEmaraDev
In your second file, if I connect the Domain Size node to the bezier curve geometry output, it prints the attributes as expected. Could this be the issue or was this just a mistake while preparing the file?
Regardless, I don't think using with contexts and depsgraphs in RNA setter and getter functions is safe.
oh, maybe I shound check the file again. I will check it out asap
Is there an other to get attribute generated from geo node attribute without using depsgraphs?
Yes, It need to link to the output. It was a mistake sorry.
I found the true problem is the obj must be link to the scene so that it can print attribute in 3.3/3.4(It didn't to link to the scene in 3.2)
3.4 with obj unlink
3.4 with obj link
Can you clarify your last point? Which object wasn't linked to the scene? The one named
Motion Control-MotionPath
? Is that in the second file you shared?get_geo_obj_attr2 (1).blend1
upload again
I still don't understand the issue. It prints
{'factor': [0.0, 0.9999999403953552], 'length': [0.0, 0.0]}
for me whenCube.001
is selected, which means the attributes are correctly retrieved.Can you clarify this?
check this file get_geo_obj_attr2 (1).blend1 and run the script
Problem: in 3.2 and early 3.3 , attribute can be printed while the object is not linked to the scene, but in later 3,3 and 3.4 , object must be linked to the scene so that the attribute can be printed
I suspect the 3.3/3.4 behavior is the more correct one, since unlinked objects will not be evaluated because they don't affect anything. So wouldn't this be expected?
What is the use case for evaluating an unlinked object?
So what I expect is I can read bpy.data.objects's attributes without linking them to the scene. If we can read their location, we shounld be able to read their attirbute.
Seems now the deps graph no longer consider the object not link to the scene?
Added subscriber: @lichtwerk
Situation is unclear for me.
I dont see a difference in 3.2 vs. master, selecting
Cube.001
after running the script and changing the test_value will equally print an empty dict {}What am I doing wrong?
poke ^
sorry, busy for moving house last week. I will give an respond tomorrow
one more poke ^
