"Blur" node in Realtime compositor not working in 3.4.0 and 3.3.0 crashes on start #100487
2 Participants
Reference: blender/blender#100487
Operating system: Windows 10
Graphics card: NVIDIA Quadro P4000
Graphics Driver: 516.94
Broken: blender-3.3.0-alpha+temp-viewport-compositor-merge.3de2575ffb23-windows.amd64-release
Broken ("blur" node of realtime compositor not working): blender-3.4.0-alpha+master.659b63751d63-windows.amd64-release
"Blur" node doesn't work in realtime compositor in 3.4.0 ("curves" node worked though) in any 3.4.0 builds. A few 3.3.0 builds crash on start (also "blender-3.3.0-alpha+principled" and "blender-3.3.0-alpha+universal-scene-description").
Download blender-3.3.0-alpha+temp-viewport-compositor-merge.3de2575ffb23-windows.amd64-release. (https://builder.blender.org/download/experimental/archive/blender-3.3.0-alpha+temp-viewport-compositor-merge.3de2575ffb23-windows.amd64-release.zip). Start blender-launcher and see it crash immediately.
Debug log of 3.3.0:
KeyError: 'object_quick_effects'
ModuleNotFoundError: No module named 'bl_ui.properties_grease_pencil_common'
AttributeError: 'module' object has no attribute 'TOPBAR_MT_file_import'
AttributeError: 'module' object has no attribute 'IMAGE_MT_uvs'
ModuleNotFoundError: No module named 'io_scene_gltf2.blender.com.gltf2_blender_ui'
AttributeError: 'module' object has no attribute 'UI_MT_list_item_context_menu'
AttributeError: 'module' object has no attribute 'TOPBAR_MT_file_export'
ImportError: cannot import name 'distributor_init' from partially initialized module 'numpy' (most likely due to a circular import) (C:\Users\Daniel.Krajnik\Downloads\blender-3.3.0-alpha+temp-viewport-compositor-merge.3de2575ffb23-windows.amd64-release\blender-3.3.0-alpha+temp-viewport-compositor-merge.3de2575ffb23-windows.amd64-release\3.3\python\lib\site-packages\numpy_init.py)
RuntimeError: Error: Registering panel class: parent 'VIEW3D_PT_tools_object_options' for 'SLCAD_PT_tools_options_object' not found
AttributeError: 'module' object has no attribute 'NODE_MT_select'
AttributeError: 'module' object has no attribute 'VIEW3D_MT_object'
Error : EXCEPTION_ACCESS_VIOLATION
Address : 0x00007FF736A97778
Module : blender.exe
Thread : 000054ac
Switching to fully guarded memory allocator.
Blender 3.3.0 Alpha
Build: 2022-06-28 12:02:00 Windows release
argv- [x] = C:\Users\Daniel.Krajnik\Downloads\blender-3.3.0-alpha+temp-viewport-compositor-merge.3de2575ffb23-windows.amd64-release\blender-3.3.0-alpha+temp-viewport-compositor-merge.3de2575ffb23-windows.amd64-release\blender
argv- [x] = --debug
argv- [x] = --debug-cycles
argv- [x] = --python-expr
argv- [x] = import bpy; bpy.ops.wm.sysinfo(filepath=r'C:\Users\DANIEL~1.KRA\AppData\Local\Temp\blender\debug_logs\blender_system_info.txt')
Read prefs: C:\Users\Daniel.Krajnik\AppData\Roaming\Blender Foundation\Blender\3.3\config\userpref.blend
Error: dropbox with unknown operator: WM_OT_drop_blend_file
Writing: C:\Users\DANIEL~1.KRA\AppData\Local\Temp\blender.crash.txt
Added subscriber: @Daniel_K
Realtime compositor not working in 3.4.0, 3.3.0 crashes on startto "Blur" node in Realtime compositor not working in 3.4.0 and 3.3.0 crashes on startAdded subscriber: @PratikPB2123
Hi, thanks for the report.
Reports on feature branch are not accepted on tracker. Also Build is quite old (28 June) and many updates has happened after that.
Blur node is not yet implemented in master(3.4) branch. Patch is under review at the moment: D15663: Realtime Compositor: Implement blur node
For more information regrading which nodes are available for real-time composting, refer: #99210 (Realtime Compositor)
Everything is working as expected so closing this ticket. Feel free to comment if there is misunderstanding.
No worries, thanks for confirming. It did work though before, right? It's unfortunate that "blur" is the first thing used in many tutorials on youtube:
I hope that it will be working soon. It's an amazing feature.
Added subscriber: @OmarEmaraDev
Hi, as said in the last comment it's not implemented in master branch(3.4)
But it's available in
3.3 compositor branch
. In this branch you're getting crash and it seems related to add-ons. See if you can use node after factory reset: {nav File > Default > Load Factory Settings}adding @OmarEmaraDev in case I'm missing something
Thanks again, I've started blender with the "blender_factory_startup.cmd" and removed "3.3" folder from the user preferences folder, so I think it should have removed all the addons. Still same behaviour though, 3.3.0 crashes on start.
As mentioned though it doesn't affect 3.4.0, so probably it's been solved already - I just couldn't find it. Attached here is blender_debug_output.txt for reference:
