temp_override() not always setting the context #100664
Reference: blender/blender#100664
Operating system: Windows-10-10.0.19044-SP0 64 Bits
Graphics card: NVIDIA GeForce RTX 3060 Ti/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 512.15
Broken: version: 3.2.1, branch: master, commit date: 2022-07-05 15:44, hash:
a2d59b2dac
Worked: Didn't work in earlier releases either
temp_override() is currently difficult to use, because it for example sets the context for
but not for
I also couldn't get it work for setting active_layer_collection and others.
temp_override_limited.blend
Cube2 is deleted
Added subscriber: @JanKaderabek
Thanks for the report.
object_convert_poll()
function was failing because active object was null in your case. Either set active object by clicking on it in viewport or do it from python apiDoes this script works for you?:
bpy.ops.object.convert(target='MESH')
Added subscriber: @ideasman42
Hi Pratik,
but that's what temp_override() should do.
If you run the script with bpy.ops.object.delete(), you can see the context (active / selected object) is set correctly and the script runs without any error (Cube2 gets deleted).
But for whatever reason it doesn't work for convert() and more, which looks like a bug.
@ideasman42 suggested to report it in the comment here https://developer.blender.org/rBf438344cf243632e497772cf1f855b9c8856fd37#351220, so I have created the task.
Changed status from 'Needs User Info' to: 'Needs Developer To Reproduce'
Just informing that it seems to be the case also with transform_apply().
To add my 2 cents, I don't think
ops.object.convert
not being overridable is tied to the new syntax, devs have confirmed that this particular operator can't be fully overriden.It was already the case with the old, dictionary syntax. see https://developer.blender.org/T93188
I'm also finding some issues with temp_override not setting the context - unless I'm misunderstanding.
Try running the script in the attached file. If it was working as expected (as far as I understand it) the context override would apply the modifiers on the object called
this is the one that should get modifiers applied!
but instead it gets applied toThis should NOT have modifiers applied
, which is what we'd expect if context override were not working properly, right?
