Non functioning shortcut #100667
Blender Cloud
Documentation
Eevee & Viewport
Import and Export
Rendering & Cycles
Add-ons (BF-Blender)
Add-ons (Community)
Reference: blender/blender-addons#100667
Win 10
AMD
Broken:
3.2
Carver add-on shortcut ctl+shift+x does nothing
Added subscriber: @balrags
Thanks for the report. Please load default preferences and check again after enabling the add-on: {nav File > Defaults > Load Factory Settings}
Hi Patrik -
Did a "Load Factory Settings" and re-enabled "Object Carver" and after selecting the cube and ctl-alt-x the "Move object" thingy appears but no DIFFERENCE selector (as shown on the tutorial screen grab below). I'm a CAD expert but a Blender virgin - pretty skilled in computer stuff. Cheers bob
Hi, I get: F13432924
Could you upload your userprefs files?: (located at:
C:\Users\user_name\AppData\Roaming\Blender Foundation\Blender\3.2\config
Added subscriber: @OmarEmaraDev
The add-on requires a single selected and active object of type mesh to work correctly, can you double check that this is the case for you?
Can you open the console and check if there are any errors printed once you execute the operator? Window > Toggle System Console.
Here they are >>>>>
platform_support.txt
recent-files.txt
userpref.blend
startup.blend
Added subscriber: @iss
It works even without selected object in create mode, so that should work... Also when I press Ctrl + Shift + X, I get no move gizmo. This should not happen with factory settings.
The files provided are not quite what was requested. Can you download alpha build from https://builder.blender.org/download/daily/, run file
blender_debug_log.cmd
and test with factory defaults again? After you close Blender 2 files will be created. Please upload these files.Please cancel this inquiry. I have loaded the CAD SKETCHER add-on which works just fine AFIK on 3.2 and does what CARVER does and more.
Thanks
