Outliner: New context menu building design #101007
Reference: blender/blender#101007
Motivation
The way we build context menus in
outliner_tools.cc
is known to be quite a mess. Basic problems:"(undocumented operator)"
, or the undo push name would differ from the operator name. Often menu entries were added that didn't make sense for the current selection, because hiding them requires special attention. With regular operators this is less likely to happen, since developers are used to implement them properly.Proposed Design
TL;DR: Add batch editing operators outside of Outliner code, they can act on context set by the Outliner. Tree elements are asked to add context menu entries themselves.
Main idea is:
outliner_tools.cc
), ask the active element to expand the context menu. For this, element types can overrideAbstractTreeElement::expandContextMenu()
.OUTLINER_MT_context_menu
. This is already the case in master.Further Considerations
The context system has some limitations still:
"selected_ids"
) can be inefficient. The Outliner context callback iterates over the entire tree to find the selection, and then allocates list elements for each.There are ideas to solve each, but they don't seem like a blocker for the design above. For now it's still fine to leave some menu entries as callbacks rather than operators, where context doesn't allow us to broadcast the necessary information. The actual logic should still be moved to the dedicated code modules. Performance impact is probably minor in practice.
Also:
OUTLINER_MT_modifier_context_menu
). But for as long as some entries may have to stick to a callback based approach, keeping things in C++ mostly seems better.Added subscribers: @mont29, @JulianEisel
Added subscriber: @brecht
I think all menu entries being proper operators makes sense. I'm less sure about asking the active element to expand the context menu, and broadcasting information through context.
The purpose of context is that operators can run in different editors. If the information is outliner specific (hierarchy etc), it's an unnecessary layer of abstraction only adding complexity, and I would just let operators access outliner data structures directly.
Letting the elements fill the menu is unclear to me, not sure how that works when you have multiple selected elements, mixed types. There might be some logic there that's much more easily expressed in a central function to fill the menu. Maybe it's not an issue, but I vaguely remember some logic that would prioritize e.g. objects over other data types in mixed selections. If it can be made to work then the extensibility is nice though.
Right the situation gets tricky with hierarchies and such. I see some options, but I wouldn't even mind outliner specific operators here, for as long as these are just thin wrappers calling into BKE code or such. My main concern is to get data-management code (even things like user counting) out of the Outliner, which should be "just a UI".
For other cases like batch deleting objects, I see no reason to keep this in the Outliner code at all. Broadcasting via context would be simple here and not require further abstractions.
I think this used to be the case, but for a while we've only been building the context menu from the active element now. In fact I've just cleaned up
get_element_operation_type()
, which seems to have been designed to support this, but wasn't used that way anymore (which I checked carefully):8f6a38ed7e
.Added subscriber: @DuarteRamos
Just to note, for library overrides it was/is quite a problem that only the Outliner has a good enough understanding of the necessary relations. I think it's worth thinking about ways to better define scene hierarchies throughout in Blender, for a whole bunch of reasons. Of course this is a bigger discussion, just noting as another way this could go. All in all I'm not too concerned, I'm glad about any gradual improvement here, and I wasn't planning to spend much time on these cases.
Would the "operatorification" of the outliner menus finally open up the possibility of more things working on selection rather than active object?
I'm thinking of things like (visibility or selectability) toggles working on all selection rather than just clicked item, or the possibility of keyframing toggles renderability toggles for multiple objects.
This is a design task so moving it out of the triaging queue
