EEVEE: Nishita Sky change Sun Rotation causes shader recompilation #101197
Open
opened 2022-09-19 21:19:41 +02:00 by PawelP · 11 comments
Broken: version: 3.4.0 Alpha, branch: master, commit date: 2022-09-16 20:05, hash: e108d67635
Adjusting Sun Rotation in Nishita Sky texture in EEVEE causes shader recompilation
while adjusting sun elevation is not causing shader compilation and allow to realtime adjustments
This makes impossible to have animated sun position.
Steps to Reproduce
**Blender Version** Broken: version: 3.4.0 Alpha, branch: master, commit date: 2022-09-16 20:05, hash: `e108d67635` **Short description of error** Adjusting Sun Rotation in Nishita Sky texture in EEVEE causes shader recompilation while adjusting sun elevation is not causing shader compilation and allow to realtime adjustments This makes impossible to have animated sun position. **Steps to Reproduce** - Open .blend file -> switch to viewport rendering - Change rotation value with slider [#101197.blend](https://archive.blender.org/developer/F13536317/T101197.blend) [nitsha.mp4](https://archive.blender.org/developer/F13518339/nitsha.mp4)
Author
Added subscriber: @Zuorion-4
Added subscriber: @TheRedWaxPolice
You mention "sun rotation" twice, I guess one should be "sun elevation"?
Author
Oh, yea. I meant that sun elevation is not causing shader re-compilation, but rotation does.
Oh, yea. I meant that sun **elevation** is **not** causing shader re-compilation, but **rotation does**.
Pratik Borhade changed title from Nishita Sky change Sun Rotation causes shader recompilation to EEVEE: Nishita Sky change Sun Rotation causes shader recompilation 2022-09-21 04:13:49 +02:00
Member
Added subscribers: @LukasStockner, @PratikPB2123
Member
Member
cc @LukasStockner
Contributor
Added subscriber: @persun
Member
Added subscriber: @pragma37
Member
While the recompilation issue is trivial to fix (just change the sun_rotation from GPU_constant to GPU_variable in node_shader_text_sky.cc),
the real bottleneck is pre-computing the sky texture.
So even after getting rid of the recompilations I still get like 3 fps.
While the recompilation issue is trivial to fix (just change the sun_rotation from GPU_constant to GPU_variable in node_shader_text_sky.cc), the real bottleneck is pre-computing the sky texture. So even after getting rid of the recompilations I still get like 3 fps.
Philipp Oeser removed the
label 2023-02-09 15:12:15 +01:00
6 Participants
Reference: blender/blender#101197
