Blender 3.3 FBX export with armature animation is broken. #101662
Blender Cloud
Documentation
Eevee & Viewport
Import and Export
Rendering & Cycles
Add-ons (BF-Blender)
Add-ons (Community)
5 Participants
Reference: blender/blender-addons#101662
Operating system: Windows 10
Graphics card: GTX 3070ti
Broken: 3.3
Worked: 2.9.1 (Tested)
FBX armature animation is incorrect on export.
Added subscriber: @Morseliot
Hi, thanks for the report. Please share your .blend file
ExportIssue.blend
Hi Pratik,
Any update?
Added subscriber: @OmarEmaraDev
Maybe this is related to the 1 FPS issue, which was fixed in
f3975a3bad
.Can you try the latest daily 3.4 build and see if the issue is fixed there? https://builder.blender.org/
Hi @Morseliot,
did you had a chance to test the daily 3.4 build as Pratik suggested?
Hi, any news? Did you check in newer development build?
Hello,
I'm sorry guys, but still wasn't able to test it on new builds, as always using Steam version and constantly in development process, literally no time to test things that was already solved.
As I mentioned in first post, was able to export the animation correctly with 2.9.1 version.
Then in Steam version (3.3) I had one more issue, as Omar Emara mentioned. The animation export only 1 frame, this was also fixed by commenting out line 126 : (30.0, 7), # Drop frame. in fbx_utils.py
Added subscriber: @P2design
Hi,
Wanted to report it too and tested last 3.4 built and it works properly.
All NLA action exported.
No bug in Unity and autodesk FBX viewer
@P2design thanks, will close then.
@Morseliot, feel free to comment or reopen the report if problem persists for you in 3.4 beta
