Mesh vertex internal naming (especially position data) #101688
Reference: blender/blender#101688
D15982 and related changes in #93602 have made it clear that the naming of mesh vertex elements has to be reconsidered.
After that patch lands,
MVert
won't be used at all. "Vertices" won't exist at all in the code.Instead, we refer to various data stored on the point/vertex domain in separate arrays.
Each of these arrays needs to have a name, and sometimes single elements could have consistent naming guidelines as well.
Currently most mesh attribute arrays are named after the corresponding attribute.
For example, we use
hide_vert
for the".hide_vert"
attribute,select_vert
for the".select_vert"
attribute, and so on.Since the mesh position is called
"position"
, I would propose referring to it with thepositions
variable name.This means internal naming is consistent with the UI, which reduces overhead when talking about the code.
It also helps to build the abstraction of attributes, where we don't think of positions as vertices but just as an attribute.
Position data should usually be accessed with
Mesh.positions()
orMesh.positions_for_write()
, and passed around with spans.In code we usually don't pass around one mesh position at a time. Instead, access usuallys look like this:
Functions currently using
coords
(as in "vert coords") should be change topositions
instead.Conceptually a vertex doesn't correspond to a single attribute on the vertex domain, so the same index variable (often
vert_index
orvert_i
)can be used to retrieve any attribute.
Abbreviations like
co
orp1
, etc. can still be used, but for clarity (less state tracking, etc), we can favor the use of direct access with indices.Changed status from 'Needs Triage' to: 'Confirmed'
Added subscribers: @HooglyBoogly, @ideasman42, @JacquesLucke
I'm not so keen on using term "positions" in isolation, mainly because I think it will lead to more ambiguous naming.
vert_*
prefix which is more obviously a vertex aligned data.Less disruptive naming for D15982 could be to user the identifier "vert_coords", e.g:
mesh.vert_coords()
&BKE_mesh_vert_coords()
this means we would mostly keep existing naming.Existing abbreviations
v_co
,v_no
&v_index
are an obvious fit and we don't need to replace them with names that aren't are more likely to be confused with other variables.An alternative could to call them "vert_positions" instead of just "positions", which at least fits with "vert_normals", developers are more likely to use
v_
prefix related variables so it avoids most of the down-sides mentioned about using "positions" on it's own, although I'd prefer stick to the current, shorter naming.I've found this helpful in general when working on geometry nodes. It's a simple rule that's predictable for people, and consistency with the UI is good IMO.
Honestly I don't agree about this. Positions aren't stored for any other domain in the vast majority of cases. I found it quite clear in most every place I used the name.
Wherever there was ambiguity, something like
mesh_positions
made it clear again. It depends on the situation though. I don't think some general rule for prefixes is necessary.This
positions
naming has been used for quite a while in geometry nodes and curve code. I haven't noticed people having the confusions you're mentioning.For examples, see
positions
in*.cc
files, orCurvesGeometry::positions()
.I don't think it does frankly. At this point I've seen a fair number of developers interact with this naming, and I've never seen that. I've seen plenty of variants of
v_idx
,vert_index
,i_vert
,vert_i
, all of which are clear, IMO.But again, context depends a lot! In many places a simple
i
is fine.v_co
andv_no
aren't used much in the codebase. Generally I don't think their necessary at all, when compared to indexing arrays likepositions[vert_i]
.When a single
Mesh
position is passed to a separate function, I'd argue it's usually as a generic 3D vector rather than something specific to meshes.Also, I think there's a real benefit to choosing simple single-word naming. "positions" is a full word, it's easy to read and type when compared to abbreviations or multi-word naming.
Regarding consistency:
If this change is made, it leaves existing uses of vertices being referenced as coordinate abbreviated to
co
.This proposal states that:
Without mentioning how to handle the inconstancy created by having a different name for a single vertex position which is still done in enough places and not likely to be phased out entirely.
Examples:
BMVert.co
(both C/C++ and Python API).MeshVertex.co
(Python API).PBVHVertexIter.co
C/C++, needed so sculpt-mode can generalize over BMesh and Mesh structures.BKE_mesh_foreach_mapped_vert
&BKE_mesh_foreach_mapped_edge
pass single vertex coordinates as arguments.More generally these conventions are used in code not directly related to mesh:
void plane_to_point_vector_v3_normalized(const float plane- [x], float r_plane_co- [x], float r_plane_no[3])
bool ED_view3d_clipping_test(const struct RegionView3D *rv3d, const float co- [x], bool is_local);
The terms
co_
/_co
as a prefix/suffix shows up insource/
over 4000 times (regex(\bco_|_co\b)
), so we should be clear on this being an accepted inconsistency, or if this is a convention to move away from.All things equal, +1 for consistency, in this case I think it's not such a straightforward case though.
Checking naming for
, some abbreviations currently include:&p1_cu = positions[segment_i];
const float3 &p2 = nurbs_positions[i + 1];
positions- [x] = math::interpolate(p1, p2, factor);
So I think it's reasonable to consider shortened names colliding with a common prefix for polygons (which isn't an issue for Curves).
Existing code already uses
p_
/p1,2,3
prefixes for positions - for curves, and I'm still not convinced it's practical to prevent it by poking developers not to use that abbreviation.Assigning short variables to vertex names in modifiers, sculpt code etc... is still going to be done, so how developers are likely to name these shouldn't be overlooked.
As noted above, I think this is done enough that it shouldn't be ignored.
I don't find using abbreviations to be an issue as long as they're consistent and unambiguous.
I read through the patch again today. I still prefer
Mesh.positions()
and passing around spans calledpositions
ormesh_positions
in the few cases where it's unclear._co/_co
is used a lot, but I do think it's okay to have different conventions for passing around a single location, which usually has different meaning than "the actual position of the vertex we're dealing with at this moment".All in all, like you say, trying to police developers to use
p1
,co_1
,co_a
,pos_1
, orposition
, etc. isn't going to work. What I think might work better though is to push developers to use spans and indices instead.In the end there will be always be some difference in these more local field names. I think that's okay. To me the most important part is that we refer to the actual position attribute consistently. I also think that helps people form the right abstractions-- "It's just another attribute on the geometry".
I'm happy to put some time into clarifying things in the code if you think that's helpful.
If keeping
co
/v_co
as an acceptable abbreviation for vertex coordinates then I'm fine to use the term positions.Although I'd prefer to keep the vert/vertex prefix
vert_positions
matchesvert_normals
and vert_colors. Otherwise it's awkward if a function takes apositions
&normals
argument, it's not obvious what they're aligned to and that they belong to the same domain.In some certain cases it may not matter for example a function might take poly-positions & poly-normals ... or vert-positions & vert-normals interchangeably, in those cases passing in
positions
&normals
is fine, although I'd consider that a fairly exceptional case.Regarding
vert_positions
vs.positions
, currently I don't think thevert_
prefix is helpful, because we only store one vertex position array on meshes, so there is no ambiguity.Normals are different because we provide accessors for vertex normals, face normals, and corner/loop normals. I don't think we should use the raw "normals" word unless the context is very clear. But that confusion doesn't exist for positions, it's just the position attribute, which fundamentally has to have a unique name across all domains.
The fact that
vert_colors
orvert_normals
have the prefix butpositions
doesn't doesn't seem like a problem to me.That said, I'm okay compromising with this
vert_
prefix on the accessor functions, it's only five letters anyway.Added subscriber: @EAW
