Clipping Region in blender v3.2 and up is causing a werid artifact #101897
5 Participants
Reference: blender/blender#101897
Operating system: Windows-10-10.0.22000-SP0 64 Bits
Graphics card: AMD Radeon RX 6600M ATI Technologies Inc. 4.5.0 Core Profile Context 22.10.1.221003
Broken: version: 3.3.1, branch: master, commit date: 2022-10-04 18:35, hash:
b292cfe5a9
weird colorful noise when using Clipping region ALT+B
it happens by simply using the clipping region, it happens in both object mode and edit mode
Diagnosis that I tried (USEFUL NOTES{F13703419} FOR FIXING THE PROBLEM)
what is causing it?:
is it gpu driver problem?
What versions of blender does it happen in?
P.S. my device -Legion 5- has a mux switch, when I did the bug report the mux switch is turned off which means the integrated GPU is disconnected thus it's not showing up in the bug report, however when I tried to check the bug
untitled.blend
Added subscriber: @4D374D44
#103716 was marked as duplicate of this issue
Added subscribers: @persun, @mano-wii, @Jeroen-Bakker, @PratikPB2123
Changed status from 'Needs Triage' to: 'Needs Developer To Reproduce'
Thanks for the report. This issue is related to newer AMD drivers
@persun also mentioned a similar problem in #100034#1403919
Not sure weather this issue requires a separate report. @mano-wii and @Jeroen-Bakker, can you comment?
Added subscriber: @slickeez
Removed subscriber: @slickeez
Thanks for the fast reply, so yeah this problem is apparently not showing up when using the recommended AMD driver v22.5.1 -I tested it- as others (jbakker and persun) have pointed out, and it's showing up in driver versions higher than that including AMD pro driver v22.q3
The driver v22.5.1 was released on 28th April, and the latest driver is released on 4th October, so as I've understood the only solution for now is to use the v22.5.1?
Is this a blender problem that blender needs to fix? or is it an AMD problem?
Thanks
Added subscriber: @LahceneB
It could be a depth buffer issue, apparently they might work differently in recent drivers, as explained here:
https:*developer.blender.org/T100034#1411628
Added subscribers: @IronArm90, @mod_moder
Hi, does this issue persist with newer AMD drivers?
Similar problem is fixed in newer drivers: #100034#1447765
