Gpencil: Delay & Frames field values in Build Modifier should be integers only #102002
5 Participants
Reference: blender/blender#102002
Operating system: Windows-10-10.0.19044-SP0 64 Bits
Graphics card: NVIDIA GeForce GTX 1070 Ti/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 512.15
Broken: version: 3.4.0 Alpha, branch: master, commit date: 2022-10-07 01:02, hash:
104fd82f74
In the Grease Pencil Build modifier, when using the mouse or the arrows to change Start Delay or Frames, the value goes through decimals instead of going directly to the next frame value.
Load a Grease Pencil Build modifier,
In the Start Delay or Frames field, use the arrows or the mouse left button to change the value, or type a number with decimals.
Added subscriber: @MumuMundo
Added subscribers: @antoniov, @PratikPB2123
Thanks for the report. Both properties itself are defined in floats so you can increment it in decimals only.
Defining them in Int would work as you are expecting.
see: https://developer.blender.org/diffusion/B/browse/master/source/blender/makesrna/intern/rna_gpencil_modifier.c$2453
RNA_def_property_float_sdna(prop, NULL, "start_delay");```
Added subscriber: @frogstomp-4
@PratikPB2123 I also see no reason why this should be a float value. Frame numbers are integers after all.
Please find the patch attached.
It's a little easier to work with that because of full frame increments.
floattoint.diff
Added subscriber: @hamza-el-barmaki
question: can float value be used in appropriate way with NLA as action strip because strips is scaled by float frames especially ... or this has no relation or any probleme ?
Changed status from 'Archived' to: 'Needs Developer To Reproduce'
This is not limited to GPencil object. Build modifier for mesh object also has
frame
property in float.I agree that having these values in integer make sense. Forwarding this report to devs
Added subscriber: @edward88
The frame number is often represented as float, a few other examples are
My guess is that this was made to have more flexibility while calculating values in scripts and drivers.
Might be another argument to seperate the UI values from the actual ones, additional to the fact that users without programming background can be confronted with FP rounding errors by simply decreasing / increasing values with the widget arrows. I don't know if that's something that could be done.
In the the object Build or Wave modifiers using the mouse only goes through tenths though (but I'm able to enter values like 1.23 manually)
so I guess it's possible to just to make the arrows/mouse add 1 instead of 0.01
right now, it's not practical to go through 100 decimals just to move 1 frame.
