Simple File from Beginner Crashes Blender 3.3.1 #102133
Reference: blender/blender#102133
Operating system: Windows 10
Graphics card: NVIDIA GeForce GTX 1050 Ti with Max-Q Design
Driver versions tested: 522.30 and earlier
Broken: 3.3.1
Worked: 3.3 (?)
Crash when file is opened and Shading tab is clicked.
File contains only a cube, plane, camera, 3x lights.
Open the attached blend file.
Select the Shading mode tab.
Crash is observed.
Added subscriber: @serialprimate
system-info.txt
Added system-info.txt.
blender_debug_output.txt
blender_system_info.txt
blender.crash.txt
Output of C:\Program Files\Blender Foundation\Blender 3.3\blender_factory_startup.cmd
Output stack trace in the crash txt file does not seem long enough. Needs a debugger.
StartUp3.blend
Added the blend file.
Thanks for the report. I'm not able to redo this in 3.3.1
Could you reproduce the crash with factory settings?: {nav File > Defaults > Load Factory Settings}
Crash occurs in module related to GPU driver so factory reset may not help. Have you recently changed GPU settings?
Hey @PratikPB2123, Thanks for having a look.
I'm just checking, but is the system information in your post your information?
I did try remaking a new default scene and it works using the same preferences, so that is why I suspect it is something to do with the blend file that I attached. It might be in the driver, but the backtrace isn't long enough to know.
Anyway, after loading factory settings as requested I can confirm that it still happens with the blend file that I shared above.
I wasn't sure what the next task state was, so I put back to triage?
Hi, yes, the system information is of my system.
Thanks for resetting the status. I or some other triager will check again your report.
Added subscriber: @OmarEmaraDev
Seems similar to #85977. But that one is supposedly fixed.
Hi, could you check whether crash triggers on running blender through
blender_debug_gpu_glitchworkaround
batch file?Hi, any updates?
