Artifacts in viewport Solid shade #102227
2 Participants
Reference: blender/blender#102227
{F13840219}System Information
Operating system: Windows 11 22H2 Build 22621.755
Graphics card: NVidia RTX 3090
Broken: 3.3.1 LTS
Worked: 3.2.0
Since the introduction of Release 3.3.x when I zoom out in status viewport shading solid, there are plenty of artifacts on the object faces. The issue is always reproducible in all releases starting from 3.3 to Release Candidate 3.3.2.
Start Blender, create a cube in viewport shading solid, zoom out in object mode. Suddenly the artifacts are visible and massive.
Added subscriber: @LenioCrameri
Hi, thanks for the report. Please upload system info file: {nav Help > Save system Info}
Also try to reproduce the issue with factory reset: {nav File > Defaults > Load Factory Settings}
Since multiple versions (3.3, 3.2) are affected, factory settings may not help. But worth to check in case you've imported settings from previous version.
Hi Patrick, thank you for your reply. Strange. I copied my settings in the %Appdata%roaming profile and renamed it. Started Blender and created new settings. I encountered the same issue! Deleted all the profiles and started again and the issue is gone! Now shading looks good. Sorry for that, but I cannot understand why it was not working after have renamed the 3.3 folder.
You can close the ticket.
Thank you for your support.
