Some particles do not appear in the render when the 'Vector' pass is enabled #102761
6 Participants
Reference: blender/blender#102761
Operating system: Linux-5.19.17-2-MANJARO-x86_64-with-glibc2.36 64 Bits
Graphics card: NVIDIA GeForce RTX 2060 SUPER/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 470.141.03
Broken: 3.2.2 - 3.3.1
Worked: 2.79
Particles in Render don't match particles in viewport. Some particles do not appear. When they move very fast the issue is more visible.
It happens when we enable the pass
Vector
Render As
toObject
Instance Object
choose the CubeGravity
to0.0
Render Engine
toCycles
Vector
Note that the particles closest to the plane disappear
particles displaced.blend
Added subscriber: @slepy8
Added subscriber: @mano-wii
The particles don't have a delay, the newest ones just don't appear in the render.
I can't reproduce the problem from scratch.
This was the file I used:
particles.blend
Can you give us more clear instructions on how to reproduce it from scratch.
Create a 'Plane'
Create a 'Cube'
Assign Particle system to the plane.
In this particle system go to Render->Render As -> select 'Cube'
Move 'Cube' away to see the 'Plane'
In particle system settings go to FieldWeights->Gravity -> change to '0'
In particles settings you can change Velocity->Normal to a higher value. This will show the problem even more.
Create 'Camera'
Play animation. Render it at any frame and compare the result.
You can bake particles. No difference in outcome (baked/unbaked).
I followed these steps exactly, but I can't reproduce the problem.
Let's see if someone else can.
untitled.blend
Added subscriber: @iss
Same here. Can't repro from scratch.
I checked your blend file. Indeed - looks correct.
Did you look into mine? Does it work fine for you?
If in my blend file an error is visible, than it must have something to do with personal settings of Blender on my side. But which one?
I also tried to locate this setting.
The only thing I noticed is that the problem is only seen in Cycles.
For a bug report to be complete, it is important to identify what caused the bug.
I figured it out.
It happens when you have "Vector" pass enabled in View Layer Properties.
Particles delayed in render view vs viewport.to Some particles do not appear in the render when the 'Vector' pass is enabledChanged status from 'Needs Triage' to: 'Confirmed'
Added subscribers: @brecht, @LukasStockner
As far as I can tell, this is because the Vector pass needs motion data - in particular, it needs to know where the particle was in the previous and next frame. If it was just spawned, it doesn't have a previous position, so I assume that Cycles just skips it in that case.
You can reproduce this by enabling motion blur and setting the shutter time to 2 frames, it causes them to disappear as well.
@brecht, do you think this is something worth improving (e.g. assuming zero motion for particles that just spawned for the purpose of the Vector pass) or is this just a known limitation?
I've considered this a known limitation up to now. The simple alternatives seem bad too. Making the particle stay still would look bad when all other particle are moving fast, and extrapolating motion can lead to a particle appearing on the other side of a surface it is supposed to collide with.
The better solution I think is to hide the particle only on specific timesteps, but it's unclear how best to represent that in the BVH, if it's possible to do it at all in Embree and OptiX. Maybe it's possible with a NaN transform or something but obviously that could cause other issues.
To avoid it being visible, I guess a zero-scale transform might be enough? That still leaves the question of what to use for the "previous frame" motion vector, but there I guess using the next-frame vector would be okay.
I don't think it's enough? It would interpolate from zero scale to full scale, not be invisible.
The bug report I filed (#104539) led me here. I don't see an answer to the issue. I looked for the vector pass option in layer properties, but that option is not available (greyed out). Can I assume this is still an open bug?
This bug report is indeed open.
