Crash when editing geometry node tree or curves in the graph editor #102766
6 Participants
Reference: blender/blender#102766
Operating system: Windows-10-10.0.19045-SP0 64 Bits
Graphics card: NVIDIA GeForce RTX 3070/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 526.98
Broken: version: 3.4.0 Beta, branch: blender-v3.4-release, commit date: 2022-11-24 16:55, hash:
959f3cd645
I have a big scene I cannot share it here, with a bit of everything in it, one library override rig with animation, two vdbs, two or three geometry node trees. I can tweak the nodes and the animation curve for a minute, and then it crashes. Here is the stack trace if it can help :
animation5.crash.txt
bug_video.mp4
bug11.blend
robot_ref_bug.blend
bone_camera_target
)Move the keys in the graph randomly
Chance of reproducing the bug is very low, sometimes it takes 2 minutes of clicking.
Added subscriber: @thornydre
Added subscriber: @iss
From crash log, issue seems to be related to some overridden object. Unfortunately, without sample .blend file it is not possible to fix the issue. Can you simplify file as much as possible, so it can be shared?
I updated the files, hopefully it is not to much, and hopefully it can help.
I am able to reproduce crash, sometimes after many clicks only.
So far I saw asserts being hit in debug mode:
On file load,
BLI_assert(ptr != NULL);
in:And after many vertices moved in graph editor:
BLI_assert(removed);
in:It does not crash with release build within debugger.
Random crashes occuringto Crash when editing geometry node tree or curves in the graph editorChanged status from 'Needs User Info' to: 'Confirmed'
Not quite sure what module is responsible for this one, will assign to core.
Don't really want to raise priority, since I don't have a way to reproduce the issue reliably.
Added subscribers: @Sergey, @mont29
@iss not 100% sure, but your assert sounds a lot like a 'running out of memory' issue (
BLI_memarena_alloc
failing and returningNULL
).Regarding the original report, I think it actually shows a root issue in liboverrides diffing, in theory this process is only supposed to access data, but if it finds some changes that are not allowed, it tries to reset the values from linked data. This is done through RNA, which may call DEG update tagging and/or send notifiers to the window manager. Neither of these are threadsafe currently.
Talked already with @Sergey about it, we have two options:
While solution #2 is likely to have a performance impact (in case there are a lot of IDs needing some values resetting), it is probably much safer in absolute, since some RNA property value setting code can have other thread unsafe behaviors, like modifying other IDs etc. (think e.g. about material assignment code...).
Would also be good to check in the node editing code though, since it should not allow modifying non-editable liboverride values, some operators there likely need some modifications of their
poll
functions...Added subscriber: @SteffenD
This issue was referenced by
d05909a70c
Changed status from 'Confirmed' to: 'Needs User Info'
OK, so I never managed to reproduce the crash here, but made a fix based on the trace from original report.
You can find the code in branch
#102766
, and some builds on https://builder.blender.org/download/experimental/ (for a few days, also named#102766
).Please let me know if you can still reproduce the crash with these changes.
Added subscriber: @EvaVomhoff
@mont29 I have checked this with branch
#102766
and was not able to reproduce crashChanged status from 'Needs User Info' to: 'Resolved'
