Shape size of the point, spot and area light not behaving correctly when animated in EEVEE and Cycles #102853
Reference: blender/blender#102853
Operating system: Windows-10-10.0.19044-SP0 64 Bits
Graphics card: NVIDIA GeForce RTX 4090/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 522.25
Broken: version: 3.5.0 Alpha, branch: master, commit date: 2022-11-28 23:04, hash:
3d1594417b
Shape size of the point, spot and area light seems like they are depending on each other when keyed.
When switching from a spot to an Area (for example) it is impossible to change the value
of "Size X" if it was previously keyed in the spot. Changing this value makes the "Graph editor" and the "object data properties" display the change correctly like it was successfully keyed but changing the frame makes it go back to the "Spot Radius" keyed before in the timeline.
The way around is to change the light to spot, change the "radius size" value to what you want your rectangular "Size X" you want and change back to rectangle and then it works.
It seems the bug does not occur (or at least stay) when I'm moving with the mouse in the timeline, it is only the case with shortcuts or buttons to navigate between keys/frames.
Still the bug exist and we can see it by making a render, the frames where the type of light changes is bugged, different from the next ones.
Frame 10
Frame 11
Frame 15
Frame 16
Bug_Repport_AreaRectangular.blend
Hope it is detailed enough, have a good day and thank you for your work ;) .
Added subscriber: @The-Rope-Dude
Added subscriber: @mano-wii
These properties share the same location in memory.
There are some small advantages to doing so.
They can be separated to solve this problem. But that would require other changes like versioning.
Not sure it's really worth the change.
The workaround seems less impactful.
Added subscriber: @ZedDB
After some further investigation with Germano and some input from Bastien, we decided that this should be fixed by having each RNA variable point to a different variable in DNA.
Otherwise you run into issues like this where two different RNA variables drive different settings in unintuitive ways.
This issue was referenced by
fbc2c4c331
