Musgrave texture glitch #102884
6 Participants
Reference: blender/blender#102884
Operating system: Windows 10
Graphics card: NVIDIA Geforce GTX 1050 Ti With Max-Q design
Broken: 3.3.1 also tried 3.2 and 2.93
Worked: none
Short Description
Musgrave texture have glitch in Object mapping mode
I`m opening default scene and adding Musgrave texture into the cube shader, setting mapping to object, and then while increasing detail and lacunarity parameters and lower dimension, strange glicth tiles appears. those tiles become more explicit while tweaking detail and dimension parameters, and change position while tweaking lacunarity
Appears only in cycles (not eevee) but both in GPU and CPU mode
Steps to reproduce
cycles
render engine#102884.blend
system-info.txt
Added subscriber: @kitbukoros
Hi, thanks for the report. Can not really reproduce in 3.2 and following versions. Can you reproduce in uploaded file?
#102884.blend
Here it is
Also I deleted 3.3 config folder and downloaded portable 3.3 version to check without addons and result is the same
Thanks for checking.
Do they only appear with cycles render engine and device is CPU?ignore this question, you've mentioned already in the description :)I'm not really able to repro this locally.
Your GPU driver also seems up-to-date
I suspect it has something to do with my hardware config, but can`t figure out what
I
m using lenovo notebook it has also integrated graphics however I
ve tried all options and glitch appearsI have also used external additional graphic card but can`t check it right now it is in other city
Added subscriber: @OmarEmaraDev
Does the glitches appear all around the cube or only on specific sides? Can you bake the material to a texture and attach it here so we can investigate it more thoroughly?
here is the video and baked texture
glitchh.mp4
Added subscriber: @mod_moder
Can't confirm
Added subscriber: @iss
Can't reproduce either.
I see a lot of addons is used, would check if loading factory settings will help. Not likely it would, but just to eliminate variables.
I`ve already tried with 3.3 portable with clean config
Somehow glitch is not reproducing in Blender 3.4
I`ve installed it recently and restored the configuration from 3.2 but everything is ok
Added subscriber: @deadpin
I can reproduce the problem in 3.3.1 but not with 3.3.2, 3.4, or 3.5. Remember to use Cycles not Eevee - it will show up with CPU as well as GPU (both CUDA and Optix would show it).
@kitbukoros Can you try version 3.3.2 released last week (https://www.blender.org/download/lts/3-3/) and see if it still is a problem for you? See below for an example:
3.3.2 is ok, no glitch
Thanks for checking, will close then.
