Incorrect and Confusing Units for String to Curves Node #102906
6 Participants
Reference: blender/blender#102906
Operating system: Windows-10-10.0.19044-SP0 64 Bits
Graphics card: NVIDIA GeForce GTX 745/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 517.48
Broken: version: 3.5.0 Alpha, branch: Unknown, commit date: Unknown Unknown, hash:
rBUnknown
Incorrect and Confusing Units for String to Curves Node, depending on Scene / Units
If Scene / Units is set to Metric this node looks like this:
{F13984816,width=100%}
Character spacing is shown in meters, and that is so odd that it might as well be shown in "number of chickens". Our current Character Spacing is already done strangely enough. This value is divided by 2 then 0.5f is subtracted from it. That value is a portion of the font's em square that is added to each character. So a value of 1 means no change to character spacing. 0 means that 0.5 of an em is subtracted from each one. That "1" means default is bad enough, but much worse to show it as one meter.
At minimum we should show this as unitless. Better would be to not do the division and shifting and therefore show "0" as default and add "em" as unit. This would match with CSS letter-spacing.
Word spacing is similar, but is a factor multiplied against each character's advance. So again, "1" means normal, 0 means that a space has no width, a 2 means a space is twice as wide. No relation to grid size. So showing "1 meter" is pretty bad.
This also should be unitless. Ideal would be to change it from a factor to a absolute value added to the width of space characters. That way it can also be "0" by default and show "em" as units. This would match with CSS word-spacing.
For even more oddness, this what it looks like in Imperial
{F13984832,width=100%}
As in normal and default character width and normal word spacing are shown as "3.28 inches"?
Added subscriber: @Harley
Line Spacing should also shown as unitless.
Although it seems correct at first. When
Size
is set to 1 then having Line Spacing set to 1 does give you 1 meter between lines. However, set the size to anything else and you will find that "1 meter" for line spacing is not actually one meter. It is actually 1em or so.Changed status from 'Needs Triage' to: 'Confirmed'
While I think some of your points make sense, I think there's some value to having units here, even when they're not perfectly aligned to world units in the end.
Actually, it seems like another way of thinking about it is that the font data scales the input sizes with units. If the font data is unit-less, that even makes sense conceptually.
Maybe a compromise would be to have one or two of these inputs have units, and the rest scale based off of that. For example, "Size" could have units, and the rest of the inputs could scale based on that.
Character spacing is something that can be made tighter, or looser, or left the same.
We have made the odd decision of scaling the UI value so that "1" means "keep it the same". With it set that way the character spacing is default and normal. When the user selects "0" it means "make the spacing tighter by subtracting the width of an 'n' from every character. Setting it to "2" means "make the spacing wider by adding the width of an 'n' to each character in the string. Yes, it is that weird.
So the default of "1 meter" or "3.28 feet" has no relationship to real-world units of any kind. This UI setting is treated as "0" under the hood.
Or another way of looking at it... See that the same settings for 3D text objects outside of Geometry Nodes do not show units:
{F13998902,width=100%}
The subtypes were just set incorrectly when copying these to Geometry Nodes.
Another option is to change the property subtypes to PROP_PERCENTAGE. That would be the best match of what the user sets to the results they get.
Added subscriber: @mod_moder
I think still measuring in chickens is not something that is suitable for procedural modeling. The height of the character should at least somewhere be in real units.
The node should really give some way of mapping characters to real locations in the resulting geometry. Should letters be 1cm tall in general, or are they on a large billboard where they should be 1m tall?
To me that's a totally reasonable thing for the node to do. I understand the text code is really weird and does stuff like using an "n" for character spacing, but I think the conceptual goal of the sockets is more important for their units.
I'm not saying they should all be units-- sometimes the units really do conflict with each other. For example the "Size" has an influence on the absolute value of the other inputs in the end.
But having no way to map to a size in the world seems to be a regression in friendliness, it requires adding a separate transform node afterwards.
Maybe we just decide to require that, but then the default size of the letters seems very arbitrary, so I don't think that would be better.
The font "size" could remain in real units if you like since that is sorta close, some times, maybe. The following fonts are all set to "1", but the heights vary from about 0.2 to about 0.8 meters in height. So not sure how useful showing "1 meter" is. It is really a scaling factor, not a linear measurement.
{F13998997,width=100%}
The other things: Character Spacing, Word Spacing and Line Spacing are just not real-world values. They are either factors or they are values that we have scaled so that they are nearly factors with "1" just being the mid-value, not a linear amount of anything.
I hear your point, but I see the font size as a scaling factor for the size input. The final world units have to come from somewhere. Either they're implicit or they're exposed in a socket.
Yeah, that makes sense. Either we change the way it works to use them as real linear values or change the units. The former sounds interesting in the long term, but might be tricky for backwards compatibility.
What I mean is that when you print text in any font (on paper), you can usually tell in advance what size the font will be. Often the user does not need to know it after the fact, but enter it directly.
This patch makes the font sizes a little closer to each other: D16608: Refactor: VFont Metrics
Factors are always factors. Otherwise you could set that the character spacing is such that 0.02 meters is added to each character. But then the moment you change the font size you'd have to set that again. The same with line height - you don't want to reset that every time you change the size, you want that to be set with factor against the font size.
I really feel like this issue has gotten more complex than it really is.
The code in Geometry Nodes does not do anything special; it has the same types of inputs with the same numerical ranges as for (regular old-style) Text Objects, calls the same functions, and gives a similar result.
But Text Objects set property types of "PROP_FLOAT, PROP_NONE" for size, space_line, space_word, and space_character (rna_curve.c) and therefore shows these inputs without units to users in the interface, regardless of scene units.
Geometry nodes sets these same inputs as "PROP_DISTANCE". This means that they display the same if Scene unit is None, but have "m" or "'" appended to the values if you set the scene units to Metric or Imperial. If you want these values to be real distances then you would have to do some further calculation, not just add an "m" to them, since they are factors, not distances.
I would love to discuss how we do this badly now and all the ways we could make it much better. But this problem is that there is accidentally appended "meters" and "feet" to values that are actually multiplication factors. Here is a user being confused by this: #102593 (Geometry nodes/Text Object: negative space character width). This is because he set "0 meters" for character spacing and "0 meters" for word spacing, unware that these were factors and that the units were meaningless.
Added subscriber: @CharlieJolly
Added subscriber: @Vyach
think, the best way is to have absolute and relative measurements or tools/parameters for these approaches.
As we have Set position with two inputs «position» and «offset» for example.
As far as fonts and characters are different we should use font-relative units as em or string height or may be [hy] height,
also we need relative points as baseline, proper character positions, and character width as metric and em units.
Because for text formatting it is more important to have ems, but when we want to match string with exact length, we need ability to know all real sizes.
@Harley
Yes, this is wide task to match a lot of needs of procedural modelling.
As I told erlier, we need addition to character and word-space width and we need character width multiplicator, to do exactly this (tracking/spacing multiplication):
2022-12-07_03-08-29.mp4
It is not odd, if 1 is a scale.
The reason that "1" is odd as the "normal" for character spacing is that it is a "shifted scale" so the under the hood that "1" is treated as zero. This means that a user cannot really select less than zero and they don't know what is happening at that zero point (a reduction in advance of an arbitrary 0.5f em).
Character spacing is best exposed to users like CSS does it (as "letter-spacing'). It is an amount ADDED to the advance of each character. This means that "0" is normal, 1 would be adding 1em to each character, and -1 would be removing 1em. And yes, this could also be exposed as absolute dimensions. This also means that there is no negative limit. https://w3c.github.io/csswg-drafts/css-text/#letter-spacing-property
CSS does similar for word spacing, where it also means an addition to the normal width of a space character (and U+00A0, U+1361, U+10100, U+10101, U+1039F, U+1091F0 . Again, with zero being normal. This also means you can have negative word spacing. https://w3c.github.io/csswg-drafts/css-text/#word-spacing-property
@Harley got it, thanks.
