GPencil: SVG exporter generates wrong stroke thickness #103061
5 Participants
Reference: blender/blender#103061
Operating system: Windows-10-10.0.19044-SP0 64 Bits
Graphics card: NVIDIA GeForce RTX 3090/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 526.86
Broken: version: 3.3.1, branch: master, commit date: 2022-10-04 18:35, hash:
b292cfe5a9
SVG seems to allays export a single thickness, while in the Blend file there's different thicknesses.
World space lineart apparently attempts to emulate the shrinking line width of the camera angle by exporting each segment with a different line weight. This makes post processing in Illustrator/Designer/Inkscape near impossible.
Screen space lineart should then instead produce a constant line width according to the displayed line thickness. Unfortunately, with screen space on, that seems to get ignored on SVG export.
lineart.blend
Added subscriber: @RobertS
Added subscriber: @OmarEmaraDev
I can't reproduce that, all lines have constant thickness for me. Can you attach the svg itself?
I think you misunderstood. The bug IS that the SVG has a single thickness, while in the Blend file there's two different thicknesses.
Added subscriber: @mano-wii
Changed status from 'Needs Triage' to: 'Needs Developer To Reproduce'
Thickness is in pixels, and thus depends on the resolution of the final image.
It is a subject of discussion. See for example #100595 (Line Art Thickness doesn't consider Render Resolution Percentage)
But I can notice that the thicknesses are always "normalized" even with the option "Normalize" in the export settings disabled.
This happens because apparently
BKE_gpencil_stroke_is_pressure_constant()
always returnstrue
.{https://developer.blender.org/diffusion/B/browse/master/source/blender/io/gpencil/intern/gpencil_io_export_svg.cc$204-205}
I don't know if this is intentional. This seems to make the Normalize option useless.
Lineart doesn't export line weights in screen space to SVGto Exporter 'Grease Pencil as SVG' always normalize stroke thicknessAdded subscriber: @antoniov
@mano-wii The normalization is done if all points of the stroke have the same pressure. This is done because the PDF export lib can handle a maximum number of thickness change and the export function tries to reduce the thickness changes. (SVG export works similar to PDF) If the pressure is equal in all points, then thickness is equal for all strokes, so I don't see a problem in the export itself, but the generated stroke... maybe LineArt is doing something to simulate the pressure change but without changing the pressure.
Anyway, I will take a look.
I have been testing and the scene contains 3 strokes with all points with same pressure, so the auto-normalization is correct. What I have seen is that the thickness of the strokes is 2 or 5 pixels and this is a very thin lines, so when you export the precission of the calculations to determine the thickness gets in all cases 2...if you add a Thickness modifier on top of the Lineart, you will see that all is working in SVG and PDF.
Note: I applied the Lineart modifer and separete the strokes to make easy the debug.
@RobertS What is the resolution of your screen?
This issue was referenced by
94e7e83cd9
85a743e08b
Changed status from 'Needs Developer To Reproduce' to: 'Resolved'
Exporter 'Grease Pencil as SVG' always normalize stroke thicknessto GPencil: SVG exporter generates wrong stroke thickness
