mixRGB node becomes UNDEFINED when switching to 3.4.0 #103252
5 Participants
Reference: blender/blender#103252
Operating system: Windows 10 Home - OS Build 19045.2364
Graphics card:
Broken: 3.4.0
Worked: 3.3.0
When switching to 3.4.0 mixRGB nodes in the shading editor will be labled as UNDEFINED and become overlayed with red. This affects all materials in a scene that us mixRGB nodes causing then to appear as the default grey color in renders. It seems to have to do with a failure to convert mixRGB to the new Mix node.
Open a .blend file that contained materials with mixRGB nodes in 3.4.0.
Blender mixRGB node broken.blend
Added subscriber: @DinnngRoomTable
Hi, thanks for the report. In newer version MixRGB node is replaced by mix node.
This compatibility is expected when you open file saved in 3.4 in previous versions. But your file seems broken in both version.
Did you save the same file in both versions? 3.4 and then in 3.3? In such way I'm able to reproduce this (but this is not a bug)
Yeah I realize that the node is supposed to be replaced, but some times it after successfully converting into the standardized mix node it would break and become undefined. I had already removed blender 3.3.0 from my computer so I don't think it could be caused from the way that you said. I uninstalled and then reinstalled 3.4.0, as the problem would occur every couple of hours and haven't had the problem appear since, so the only thing I can think is it had something to do with that.
mixRGB node bceomes UNDEFINED when switching to 3.4.0to mixRGB node becomes UNDEFINED when switching to 3.4.0Changed status from 'Needs User Info' to: 'Needs Triage'
Added subscriber: @OmarEmaraDev
The attached file was last saved in 3.4, and the type and idname are correctly set to
SH_NODE_MIX
andShaderNodeMix
, but it appears the storage is lost, which happens when he file is saved in an older version.Could you replicate this issue from scratch without saving in an older version of Blender? Otherwise, I think we should assume that this file is in an invalid state regardless.
Hi, any updates?
Same problem.
I also encountered this problem, although my issue seems to use the Asset Browser.
In 3.3 or earlier, create a material that uses a the old MixRGB node, and mark it as an Asset. Save and close.
In 3.4, create a new blend file, and assign the asset material to an object via the Asset Browser. If you inspect the Shader graph immediately, you will see the MixRGB(old) node successfully converted to MixRGB(new), and the scene renders correctly.
However, if you save the file with 3.4, close it, and open it in 3.4 again, the node will now be Undefined and red, and the object will render in default gray.
The same thing happens if you open a 3.3 file via the 3.4 Asset Browser (right click -> Open .blend file), then save it somewhere and open it again in 3.4. Looks converted at first, but is broken after save/reopen.
