Cycles GPU crash when switching to Rendered 3DViewport --MacOS 13.1-- #103327
10 Participants
Reference: blender/blender#103327
Broken: 3.5.0 Alpha, branch: master, commit date: 2022-12-18 20:06, hash:
50c7eb14f4
Worked: 3.5.0 Alpha, branch: master, commit date: 2022-12-16 20:43, hash:
4254810e50
(works fine)Short description of error
Instant crash of blender when switching to rendered 3DView.
Compile latest 3.5 version as of 2022-12-18 20:06, hash:
50c7eb14f4
open empty scene provided below and switch to rendered 3DView.
gpu.blend
xcode 14.1
latest brew updates
(cycles-cache & build-darwin folders deleted before compiling )
PS: When switching to CPU there is no crash. Only GPU !
Added subscriber: @Nurb2Kea
#103290 was marked as duplicate of this issue
#102453 was marked as duplicate of this issue
#103302 was marked as duplicate of this issue
Added subscriber: @OmarEmaraDev
Can you attach the crash log created by Blender when it crashes?
Even with the terminal, you won't see anything when it crashes.
3.5 is getting worse since a month, and I'm not able to tell !
4254810e50
(the version before this one) works fine and I even can render animations again what wasn't possible a week ago...Nothing in it:
Blender 3.5.0, Commit date: 2022-12-18 20:06, Hash
50c7eb14f4
bpy.ops.initial.settings() # Operator
backtrace
Python backtrace
Continues with : 3.5.0 Alpha, branch: master, commit date: 2022-12-19 20:56, hash:
c2a8d8b18d
Can you perhaps check if you can find any relevant logs as per https://apple.stackexchange.com/questions/26480/where-can-i-find-my-crash-logs?
Added subscriber: @Alaska
This is most likely the issue described here: https://blender.chat/channel/render-cycles-module?msg=BGRhNkijQJPTXbm77
Added subscriber: @LukasStockner
Hopefully @LukasStockner or someone else gets around to fixing it soon.
That's what I found.
Blender-2022-12-20-125131.ips
Added subscriber: @Kent-Davis
Added subscriber: @iss
Can confirn, same stacktrace as in #102453, but different function was compiled. Will confirm this task and merge #102453 here, since this is easier to reproduce.
With debugger code got stuck on exception in MetalKernelPipeline::compile() on printf "Error getting function"
Added subscriber: @shugo
Added subscribers: @DanielBrylka, @Memento
Should be fixed by
4c295276f0
in recent nightly builds. Would be great if someone could double-check so we can mark this resolved.yes, the latest build from the 6th of January (and from the last days too) does indeed compile the render kernels with two instances of MTLCompilerService on my intel 2020 iMac 27" (with 16 GB 5700-XT).
Then the workshop.blend scene renders in about 52s and uses a bit over 50% of the GPU.
This is still only half as quick as the Blender release 3.4.1 - here it takes only 28s.
What could be the reason for the slowdown?
Since the support of Metal in Blender I ran the same benchmark each time a new version or system update came out. Here are the results:
Intel iMAC 27“
Blender 3.0
iMac 27“ CPU
60s
Blender 3.1
iMac 27“ CPU
56s
Blender 3.2 Alpha (MacOS 12.3 Metal support!)
iMac 27“ GPU
30s
Blender 3.4 Alpha (MacOS 12.5)
iMac 27“ GPU
30s
Blender 3.4 Alpha (MacOS 12.6)
iMac 27“ GPU
28,4s
Blender 3.4 Alpha (MacOS 13.0)
iMac 27“ GPU
28,76s
Blender 3.5 Alpha (MacOS 13.0.1)
iMac 27“ GPU
28,23s
Blender 3.4 Release (MacOS 13.1)
iMac 27“ GPU
28s
Blender 3.4.1 Release (MacOS 13.1)
iMac 27“ GPU
28s
Blender 3.5 Alpha (MacOS 13.1)
iMac 27“ GPU
52s
I am having strange general crashes of the iMac that I cannot pinpoint. But for sure they are more often since Ventura.
I checked my machine and RAM. My uninformed guess is it has something to do with the "WindowsServer", Metal and the GPU.
Thanks for fixing the Alpha again. Best Daniel
Can confirm this being resolved, closing.
There still bad crash during GPU Compute (Computer) on properties during Cycles render. See my other new ticket.
@DanielBrylka
@iss
#104596
Also check my youtube with my link.
There is not resolve.
Hi @Kent-Davis, I just checked on my iMac the 3.5 Alpha from the 12th of February.
I do not see any crashes for a while now and I am happy to report that at least on my configuration the render speed improved a lot again.
iMac 27“ GPU
28s
Blender 3.5 Alpha (MacOS 13.2)
iMac 27“ GPU
27s
It's clear to see in the activity monitor that my Radeon Pro 5700 XT is using up to 80% while rendering.
You have a different AMD card as far I could see, right?
I hope you find a cause for your crashes soon.
Best, Daniel
As you can see it's one step away from crashing in video 01.
The second video shows how metal backend is displaying icons and signs when scaling the ui, what never happened in OpenGL.
Operating system: macOS-13.2.1-x86_64-i386-64bit 64 Bits
Graphics card: Metal API AMD Radeon Pro 5700 XT 1.2
Broken: version: 3.6.0 Alpha, branch: main, commit date: 2023-02-20 22:04, hash:
07ae1feed2b9
07ae1feed2b9
Edit: Complete MacOS crash & reboot with :Broken: version: 3.6.0 Alpha, branch: main, commit date: 2023-03-03 23:37, hash:
d0cfbc23db81
I'm not sure if is the same issue.
3.4.1 and Beta 3.5 Crashing when changing to shading viewport, still working perfect in 3.3
No matter how simple or complex files are.
I also found that Beta 3.5 was working fine for a while and then and with no reason begins crashing when F12 is pushed even with the files that worked fine before making it not usable at all in my machine.
By the way, Beta 3.5 viewport textures look weird when Viewport Metal is used
ImacPro
3,2 Ghz Xeon W 8 Cores
Radeon Pro Vega 56 8Gb
32 Gb 2666 Mhz DDR4
Ventura 13.2.1
Check my report ticket long explain.
#105148
Thank you. Last test with 3.5β was quite better, Having problems with some addons with viewport metal enable.
ex. KitOps was fully disable and not able to work
@QBer You are welcome.
I am confirming this issue, as it has been reported other times and may be related to these other reports:
#111408: Cycles GPU Compute 5000 x 5000 pixels render F12 crashes
#112678: Regression: Crashes when uses preview or final render modes
When was it reported?
Best blender mac support!!! THX
The reason I stop reporting bugs!
(we report - you fix and test - we confirm working again)
(by the time I can't test it anymore because I don't own anymore this Intel Mac setup)
