Documentation: Object Index & Material Index available with Cycles only #103496
Eevee & Viewport
Rendering & Cycles
Needs Information from Developers
5 Participants
Reference: blender/blender-manual#103496
I spent a long time trying to understand how to use the ID Mask Node in Eevee. The documentation says "To be accessible after rendering, Object Index or Material Index render pass has to be enabled." I suggest that you specify that this also is for Cycles only. I believe it will save users time.
"To be accessible after rendering, the Render Engine must be Cycles and Object Index or Material Index render pass has to be enabled."
https://docs.blender.org/manual/en/latest/compositing/types/converter/id_mask.html#setup
Added subscriber: @KevinCBurke
Removed subscriber: @PratikPB2123
Added subscriber: @sockseight
claimed this task
submitted patch -> https://developer.blender.org/D16897
Bravo! 🙌 Thank you
you are welcome!
This issue was referenced by 9849
