Flamenco Worker can send larger preview images than the Manager accepts #103516
Closed
opened 2022-12-28 12:34:01 +01:00 by softyoda · 8 comments
Hi, it's my first time with Flamenco, I need to render 360 equirectangular stereoscopic images (4096x2048 (top-buttom for a total of 4096x4096px jpg image)
I have the following error when any worker finish to render an image :
WRN TaskOutputProduced: Worker sent too large last-rendered image imageSizeBytes=13203153
I have around 150tb free space on the nas.
Are there any settings on flamenco server to change this limit ?
Thanks for the help.
Hi, it's my first time with Flamenco, I need to render 360 equirectangular stereoscopic images (4096x2048 (top-buttom for a total of 4096x4096px jpg image) I have the following error when any worker finish to render an image : ``` WRN TaskOutputProduced: Worker sent too large last-rendered image imageSizeBytes=13203153 ``` I have around 150tb free space on the nas. Are there any settings on flamenco server to change this limit ? Thanks for the help.
Author
Added subscriber: @softyoda
Added subscriber: @Raimund58
Sybren A. Stüvel changed title from Flammenco "Worker sent too large last-rendered image" to Flamenco Worker can send larger preview images than the Manager accepts 2023-01-03 16:27:00 +01:00
Added subscriber: @dr.sybren
The Worker already down-scales the image to a maximum of 1920x1080 pixels (maintaining the original aspect ratio), so they should be relatively small when they are received by the Manager.
There is an artificial limit in the Manager of 10 MB, and your file compresses down to 12.5 MB -- this is what's causing the issue. I'll bump the limit to 25MB, that should make things work better for you.
The new limit will be released in Flamenco 3.2.
Also this shouldn't get in the way of Flamenco actually rendering your files. It just won't show previews in the web interface.
The Worker already down-scales the image to a maximum of 1920x1080 pixels (maintaining the original aspect ratio), so they should be relatively small when they are received by the Manager. There is an artificial limit in the Manager of 10 MB, and your file compresses down to 12.5 MB -- this is what's causing the issue. I'll bump the limit to 25MB, that should make things work better for you. The new limit will be released in Flamenco 3.2. Also this shouldn't get in the way of Flamenco actually rendering your files. It just won't show previews in the web interface.
This issue was referenced by 6aea02c904
This issue was referenced by 6aea02c90452954e9c8a89d1564e5e3fbd983ffb
Sybren A. Stüvel self-assigned this 2023-01-03 16:28:44 +01:00
Author
Hi, thanks for this clarification.
Do you think the 25mb limit will work with any resolution now (as it is downscale like you said) ? (sometimes I render higher resolutions).
Hi, thanks for this clarification. Do you think the 25mb limit will work with any resolution now (as it is downscale like you said) ? (sometimes I render higher resolutions).
Reference: studio/flamenco#103516
