Regression: Nodes created by the "Use Nodes" button initially can't accept inputs #103624
Closed
opened 2023-01-04 05:49:37 +01:00 by Alaska · 8 comments
Member
Operating system: macOS-13.1-arm64-arm-64bit 64 Bits
Graphics card: Apple M1 Pro Apple 4.1 Metal - 83
Broken: version: 3.5.0 Alpha, branch: master, commit date: 2023-01-04 04:05, hash: c26616b2c1
Worked: 3.4.0, and probably versions of 3.5.0 from yesterday.
Caused by e091291b5b
When a node is created using the Use Nodes button, you can't attach anything directly to any of the inputs. I have included a short video below
This is how I was able to reproduce the issue. There are probably other ways of doing it too.
  1. Select an object.
  2. Open a shader node editor.
  3. Add a new material.
  4. Select the New button (to create a new shader)
  5. Add a node like a Value node and notice how you can't connect it to any of the inputs on the Principled BSDF node.
Or follow the video attached below.
Another way of doing this is as follows:
  1. Change the render engine to Cycles.
  2. Select a light.
  3. Open a shader node editor.
  4. Enable Use Nodes in the shader node editor.
  5. Add a node like a IES texture node to the shader editor.
  6. Try and connect the output from the IES texture into the input of the emission shader. Notice how you can't do it.
    Node editor connection issues.mp4
**System Information** Operating system: macOS-13.1-arm64-arm-64bit 64 Bits Graphics card: Apple M1 Pro Apple 4.1 Metal - 83 **Blender Version** Broken: version: 3.5.0 Alpha, branch: master, commit date: 2023-01-04 04:05, hash: `c26616b2c1` Worked: 3.4.0, and probably versions of 3.5.0 from yesterday. Caused by e091291b5b **Short description of error** When a node is created using the `Use Nodes` button, you can't attach anything directly to any of the inputs. I have included a short video below **Exact steps for others to reproduce the error** This is how I was able to reproduce the issue. There are probably other ways of doing it too. 1. Select an object. 2. Open a shader node editor. 3. Add a new material. 4. Select the `New` button (to create a new shader) 5. Add a node like a `Value` node and notice how you can't connect it to any of the inputs on the Principled BSDF node. Or follow the video attached below. Another way of doing this is as follows: 1. Change the render engine to Cycles. 2. Select a light. 3. Open a shader node editor. 4. Enable `Use Nodes` in the shader node editor. 5. Add a node like a IES texture node to the shader editor. 6. Try and connect the output from the IES texture into the input of the emission shader. Notice how you can't do it. [Node editor connection issues.mp4](https://archive.blender.org/developer/F14112667/Node_editor_connection_issues.mp4)
Author
Member
Added subscriber: @Alaska
Author
Member
Author
Member
CC @HooglyBoogly as the issue appears to have been introduced in e091291b5b
Alaska changed title from Initially can't join certain nodes together to Nodes created by the "Use Nodes" button initially can't accept inputs 2023-01-04 05:56:28 +01:00
Member
Member
Pratik Borhade changed title from Nodes created by the "Use Nodes" button initially can't accept inputs to Regression: Nodes created by the "Use Nodes" button initially can't accept inputs 2023-01-04 06:38:04 +01:00
Hans Goudey self-assigned this 2023-01-04 14:18:13 +01:00
This issue was referenced by 20b2d6fc71
This issue was referenced by 20b2d6fc71803a1b23604a42317fa173b71792e6
Member
Added subscriber: @SteffenD
5 Participants
Reference: blender/blender#103624
