Cycles HIP with AMD gpu still crashes. No valid fix found. #103755
2 Participants
Reference: blender/blender#103755
AMD Ryzen 7 3700X
4x8Gb HyperX Fury Beast
Operating system: Windows 10
Graphics card: AMD Radeon RX 6650 XT 8gb
Blender 3.0.1 / 3.4.2
Broken: All versions. Recently started a massive project with a lot of different image textures, while using an RTX 2060, and 16gb of ram. Upgraded from Nvidia to AMD (dont ask why), to improve my GPU, which in all kinds of other software's, games, etc. improved a ton. Only Blender still crashes with the exact report almost every other person on the forums comes with this. The weird part about it is that material preview works perfectly fine. So it cant be the texture at fault right?
After tinkering around with the preferences, it now in both 3.4.2 and 3.0.1 (The versions i've used so far), straight up crashes. I cant find any crash reports anywhere. Searched for multiple days for any answers and all either lead up to the forum post dying down and being stopped. Or no fix given at all. Can anybody give clarity over this because i'm getting very frustrated of the fact.
Launch the file with an Radeon 6000 series gpu
Go into rendered preview, or render it entirely
Either it gives no output, or it'll crash outright.
Dreamland(MegaProj).blend
(P.s. yes I know the file is incredibly big, my. I've tried running it from one of my other drives, and crashes the exact same way.)
Added subscriber: @Lyroi
Hi, thanks for the report. I've not checked your file yet, do you've 4k textures, higher render resolutions, samples?
How much is the VRAM usage at the time of crash?
Can you share log files?:
Hey, I'm using a lot of image textures from the Poliigon addon, I have no idea if they're 4k, but since the plain im rendering is so big, I've repeated it a lot, and also put some mosaic nodes over it. I dont know if that might be the problem. However, I've just noticed that with .blend files that are NOT packaged, the rendering goes well.
This was only for a water texture, and when I tried rendering it in Blender 3.4.1, It crashed. As well, I render at just casual 1920x1080, and the big file does indeed crash.
Howerver{F14137669}
The weird part is, this file is almost the same size, uses the same typa particle systems, as well as having the same Poliigon textures. And this one renders absolutely fine, hell it renders for my feeling extremely fast since the GPU is brand new. Anyways, I'm gonna try tinkering around with the sizes themselves since it luckily still opens. For all parts, thank you for the Dreamland(MegaProj).crash.txt
Thanks. Can you share other 2 files too:
blender_system_info.txt
andblender_debug_output.txt
Does crash happen in viewport rendering only?
Did you check this? Probably you've ran out of memory
It could probably be GPU lacking, but that would be strange since the 2060 could easily render it and right after it went to "out of system memory", then I upgraded to an 8gb GPU, so it should probably work right?
Update: Managed to get it working, the project in question had the issue of way to many PBR textures, to many vertexes (I had 2 particle systems of over a million), and much more :)
In any case, thanks a lot for the helps!!!
Thanks for the update. I'll close this report.
