Clearing grease pencil data/frame/layer using python does not clear viewport #104121
Reference: blender/blender#104121
Operating system: Linux-5.4.0-137-generic-x86_64-with-glibc2.31 64 Bits
Graphics card: NVIDIA GeForce GTX 1080/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 510.47.03
Broken: version: 3.5.0 Alpha
Worked: never? (doesn't work until 2.83)
When clearing grease pencil data using python API, the strokes are not disappearing in the viewport.
They do disappear when update is sent to viewport (eg. change object mode, attempt to draw stroke, etc.)
The same problem appear when clearing a grease pencil frame or layer.
Open the "New 2D animation" template file.
Draw a stroke.
Open a Python console.
C.active_object.data.clear()
to clear out data from grease pencil object.The stroke is still visible in viewport while all data from the object has been removed.
clear_data_update.mp4
Added subscriber: @amelief
Added subscriber: @antoniov
I have no idea where the "clear" data API is defined, but for sure this problem is a missing notifier. I guess the solution is find where this
clear
is done and check if theID
type isID_GD
.So far, I found that the API function is defined in
rna_gpencil.c:2726
, and is linked to therna_GPencil_clear
C function that is defined inrna_gpencil.c:1118
.This function calls a notifier :
WM_main_add_notifier(NC_GPENCIL | ND_DATA | NA_EDITED, NULL);
which should in theory re-draw the grease pencil object in the viewport, right ?I am not sure where to check for the ID type though.
Try adding
DEG_id_tag_update(&gpd->id, ID_RECALC_TRANSFORM | ID_RECALC_GEOMETRY);
afterBKE_gpencil_free_layers(&gpd->layers);
inrna_GPencil_clear
Yay it works !
Now we only need to make it work for frame/layer clear functions, because they have as only parameter
bGPDframe*
/bGPDlayer*
which don't have anid
field.. (rna_gpencil:1104-1111
)@amelief Look at
rna_GPencil_stroke_remove
You need set this:
Then in the called function, just add the ID as parameter.
static void rna_GPencil_frame_clear(ID *id, bGPDframe *frame)
This issue was referenced by
ef39d85d7c
