VideoTexture 'cam' device number does not work and rate has weird effects 249rc1 #18634
Reference: blender/blender#18634
Category: Rendering
%%%using python of the form:
GameLogic.vidSrc = VideoTexture.VideoFFmpeg('cam', 0, 1, 640, 480)
I only seem to be able to get the first webcam (ie. 0) to work. This was a problem for me as I was using a Canon camcorder as a video source on my laptop which has a webcam already... Worked fine in Ashsid's plugin with cam value set to 1, but not on VideoTexture in RC1. Have also tried it with a second web cam and get the same result.
After a little more research I have found:
On my laptop (winXPpro, Intel Centrino Duo, Nvidia 8600m GT) only cam = 0 works. set to any other value you just get black (with later experiments I got grey).
On my desktop PC (WinXP, Intel E8400, Nvidia 8600GT), with 'cam' set to 1, a 'choose device' dialogue pops up with the available choices in it, and then only device 0 works anyway.
This was verified with the Videotexture demo file.%%%
%%%Great I spelt it wrong... I meant 'device' number in the title..sorry%%%
%%%The syntax for the camera is a follow:
Windows: VideoFFmpeg("",,,,)
cam is 0 for the first camera, 1 for the second, etc.
Unfortunately, it seems that the vfwcap driver does not handle correctly the camera number: opening with =1 never works, even if there are 2 cameras, at least on my machine; and =0 gives a pop-up windows where you can choose which camera you want to use. It could also be a bug in ffmpeg that it does not use vfwcap correctly.
Linux: same format as in Windows in which case the v4l driver is used with the name /dev/video0 for the first cam, /dev/video1 for the second, etc.
You can also specify the driver directly:
VideoFFmpeg("[:]",0,,,)
where should start with "/dev/" and optional format can be 'pal', 'secam' or 'ntsc'. Example of valid filename:
/dev/v4l/video0:pal
/dev/ieee1394/1:ntsc
I didn't try with 2 cameras in Linux but there is a good chance that it works better because the driver is named explicitely.
In any case these are problems in ffmpeg or in Windows driver. I can't fix them now. %%%
This seems to be working, despite the inconsistent API. The reported problem seems to be with ffmpeg or the windows driver.
I will close this and leave a better API as a ToDo.
