Wacom Intuos 4 tablet doesn't work with outliner #28489
Reference: blender/blender#28489
%%%Some time in the last week or so, my tablet stopped working with the outliner. I can click on the mode buttons (hide, hide_select and hide_render). I can also drag objects around. But:
Right-click (context menu) and middle-click (to scroll) using the buttons on the side of the pen does work. If I use my mouse, everything works as expected.
Actually, it does occasionally work, so if I click many times on an object it will eventually be selected. This is similar to the behaviour in the file window (except in this case the workaround of dragging does not help).
Blender version: 2.59.1 r39879
System:
OS: Ubuntu 11.04, 64-bit, with Unity
Tablet: Wacom Intuos 4 (PTK-840)
Mouse: Logitech M-U0017
Graphics: ATI Mobility Radeon HD 5430 (using closed fglrx driver)
%%%Developer note:
I can confirm this. It happens because of slight pen movement between you touched surface of pad and moved pen up. In this case KM_CLICK event wouldn't be triggered.
IMO, correct behavior would be to check if movement between PRESS and RELEASE is less than threshold for TWEAK event and generate KM_CLICK event, otherwise generate EVT_TWEAK event.%%%
%%%Attaching patch for this issue. Testing + review are welcome.%%%
%%%The patch works perfectly for me. Clicking is restored in the Outliner, and clicking in the file open window works properly for the first time in the 2.5x series. Brilliant!
I have poked around the UI a bit, and I haven't found any regressions.%%%
%%%Assigning to developer familiar with this code more than me.%%%
%%%Actually, I have found a regression: when constraining a transform by holding down the Control key, an extrude occurs when the transform is completed. To reproduce:
The vertex will be moved, and then extruded to the location of the mouse cursor.%%%
%%%Told with Brecht. There's easier way to fix it and it shouldn't fail. Attaching next version of patch.%%%
%%%The new patch works very well. It fixes the regression. I have tested a fair few functions in the UI (including some mesh tools and grease pencil) and it seems to be fine.%%%
%%%This patch can be committed I think? Looks good to me.%%%
%%%Commited into revision 40459.
Brecht, hope you don't mind i've done this.
Closing report now. Thanks to everyone here :)%%%
